Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • As per wiki instructions( http://copter.ardupilot.com/wiki/configuration/throttle-failsafe/ ) there is 3 ways that you can set radio failsafe.
        Low-Throttle method
        No signal method
        Receiver method
        I'm referring to the 3 option. It was working on AC3.1.5 and is not working on 3.2.1
        Same thing for the failsafe on AUX channels 1 to 6, on ac3.1.5 I set my camera to be pointing to a specific position in case of an loss of signal in my receiver and it's not working anymore with 3.2.1.
        I have done a detailed report of the problem here about one month ago. For me it was very useful and I'm said that it's not working anymore. I didn't see any info in the AC3.2.1 release description saying that it would be disable and besides, receiver failsafe instructions are still in the wiki.
        Thanks for your reply.
        • I had problems with the receiver method in 3.1 and 3.2. Depending on where my mode switch was it would act differently. Doesn't make sense but that's what it did. No signal method is what I prefer because it will continue in RTL even if the RX regains signal. But why it worked for you in 3.1.5 but not 3.2.1 is a mystery.
          • Thanks for your reply...
            I tried in 3 different pixhawk board, and in all of them receiver failsafe would work in ac3.1.5 but not in the ac3.2.1, so I understand that it was a firmware problem.
            Anyway, is there anyone that could confirm that the receiver failsafe method should be working in AC3.3?
            Thanks in advance.
    Copter-3.3-rc11 is now available through the mission planner’s beta firmwares link.
    This has just one change from –rc10, instead of saying “Waiting for 3D Fix” during pre-arm it gives a detailed reason like “PreArm: Need 6 sats (have 5)”.
    We're aiming to do a soft release of Copter-3.3 probably this weekend.  So that will just be renaming -rc11 to Copter-3.3 and asking the general community to upgrade to 3.3 and report any issue into the APM Forum.  We will let that go on for a couple of weeks and if nothing scary comes up we will replace 3.2.1 with 3.3 as the official, default for Pixhawk and other high CPU boards (APM2 will remain at AC3.2.1).
    Thanks all!
    • A few points.
      Can't provide bin files and can't figure out why, but that's another issue.
      This TLOG has some of the tests I managed to do after lunch, and there's something weird with FS_THR_VALUE that I had set for 960 and only after disabling the Radio Failsafe I was able to fly. Radio Calibration done.
      Radio system is DSMX and is set to bring CH3 to 930 with radio off and I can see it on the Failsafes screen.
      https://drive.google.com/open?id=0BzRxu4IwHPYCcDJiMGdMVHZtQ1U
      First impressions without auto tuning is a flawless flight but with the windy conditions I had AltHold was behaving reasonably well, PosHold was unable to get a fixed position, and Rob's Break mode was absolutely fantastic, because it kept the small quad absolutely static on the spot.
      Won't test more, until I can figure out what's wrong with the damn FS_THR_VALUE, because I don't want to fly very far without Radio Failsafe.
      ps: As a side note. I hope Paul is able to offer us all some aluminum made cars, because at 2m distance from my car (Honda) Compass Variance of the EKF goes nuts......
      now to see why I don't have logs on the damn microsd, and no warnings from the card....
      3702593313?profile=original
        Thanks for testing.
        If PosHold was unable to hold a fixed position, but Brake mode worked then it means that the issue is not a GPS quality or EKF position estimate issue.  It's most likely that the radio trims are slightly off and so PosHold thinks that you're supplying input.
        Copter-3.4 will automatically clear out the binary log files if the SD card fills up but that's not in AC3.3 (nor AC3.2.1) so it just requires some manual effort now and then to clear off the files.  The files are bigger than they use to be though so perhaps the SD cards are filling up faster than they would have with AC3.2.1.
        • Thanks Randy,
          I looked at the radio logs, and it doesn't seem to be anything related to radio inputs, as it can also be seen from the TLOGs.
          My biggest issue now is to sort out the THR_VALUE for the failsafe....
      • Ah,
        something else Randy.
        Bunny hopping on land still here :)
          Luis,
          Really we need to see logs but I strongly suspect this is a ground-effect-on-baro issue.  The Solo suffers from the same thing and you can see how it lands near the end of this video.  Solo-master has a work-around for this that we may add to Copter-3.4 but we need to review it and ensure it doesn't mess things up for other users.  If this is indeed the issue, then I think it will show up clearly as baro movement during landing and a physical change to the frame is probably the only viable solution in the short-term.
          • Just a positive reflection:
            Two examples with Land (last 7 seconds of the Video).
            https://www.youtube.com/watch?v=TYaxE3_TuLc&feature=youtu.be
            https://www.youtube.com/watch?v=Ez16y-yep_M&feature=youtu.behtt...
            No bouncing @ all. Btw., all Settings @ Quad Default , no autotune. Since I do a lot of flights at 1-2 m height, I don´t believe in ground effect issues.
            I´m always using LAND (coming usually from PosHold) and it works perfectly with -rc10,-rc11 with AUAV-X2 ,Pixhack (with internal damping) @F450 and the Pixhawk Lite cheapo @ Mini Drones 500mm Carbon Frame.
            PS: What I like about it,that the throttle hasn´t to be moved down
            Thanks a lot for the good work !
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
