Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
              • Thanks for updating the wiki page Randy- Any chance to put an indicator inside MP on the radio calibration screen? or maybe just a small "fyi" type of notation about ch2 reversal? I know it seems minor (and it is) but it would save some frustration at the field on 1st flight for those (like me) new to the Ardupilot / MP platform. If it happens cool, if not, still cool. you guys are five stars.
            • Nope, not a bug.  I think the real reason for this is lost to the mists of history.  At some point somebody had to decide if 1000 pwm was "nose down" or 2000.  There is no right or wrong answer to that question.
  • 3.3 FOR WIDER USERSSS!!!!!!!   :D  :D :D
    http://diydrones.com/profiles/blogs/copter-3-3-ready-for-wider-use?...
  • Just installed RC11 on my extended f550 (I ran earlier 3.3 RC's, but went back to 3.2.1 up until now). I re-calibrated everything, and am getting a PreArm: GPS Horiz Error as soon as I try to arm (I can see previous attempts reporting 6.1, 6.0 and the latest at 5.1). I have reported 10 sats and a DHOP of 1.4. I appreciate that EKF is not satisfied with the GPS fix, but wonder how I would be able to improve this given the DHOP value and sat count I have is about the best I can get. I'd really like to be able to use PosHold. Any advice plz?
    • The GPS Horiz Error was shortly followed with a GPS Speed Error. The sat count eventually went up to 17 and a DHOP of 1.0 and I was able then to arm without issue. I am using the dreaded M8N on a small pole/mount which is sitting well away from the other electronics and power, elevated about 4" above the arm to which the mount is attached. Something like this:
      f5501.jpg?width=400In 3.2.1 it flies great in PosHold - totally steady with hands off. Never had any unexpected GPS behaviour either in about 20 flights with this copter.
      • I have an M8N and experience similar behavior- today for example, i had to let the copter sit for about 5 minutes before being able to arm. i had 11 sats showing and 3D Fix but hdop was not low enough to arm in PosHold. I usually see the same types of speed errors, bad AHRS errors, bad gps horizon errors initally but they go away after a few minutes-   it's still a bit annoying but that's probably some of the price you pay for accuracy and precision in a gps mode.
        I still need to experiment with custom configs for the M8N. if you google "marco config M8N" you should find threads / links to a specific M8N config file which is supposed to help performance a bit. In order to load the config you need U-Center software, connect the FC to MP via USB, use 'serial passthrough to GPS' in Mission Planner, load the config file to the M8N through U-Center, save, then remove the receive wire from the GPS module so the config does not get overwritten next time the pixhawk reboots.
      • I had the same issue and it went away after I covered the bottom of the GPS mast with copper tape.
  • Anyone else have any issues with ROI? Or downloading dataflash logs? I just updated from rc12 to the official 3.3 release. Made several flights documenting local flooding due to "blood moon". One flight had issues... When I roi'ed the end of a pier, ending the ROI was unsuccessful. I could tell the ROI changed, but it did not turn to face the next waypoint, quad faced 180 and continued mission until I RTL'ed. I wanted to post a DF Log, however, the log that I thought was the correct one, just shows me sitting in the same spot, no flight data!!! Here is a video and wpt file. Will re-test after batteries finish.
    https://www.dropbox.com/s/m649eqdxhs7rlqh/GOPR3236.MP4?dl=0
    garden city flood 2.txt
    Dropbox - Error
    Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
