Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
absolutely not. drone was in the air. standard telemetry was supplied from standard Serial1 telemetry port.
can software confuse somehow Serial1 with USB port now?
A while back on APM controllers the stack would sometimes see the USB as connected even when it was not. Kev went so far as writing in a detection for this event in his Log Analyzer but I haven't seen this happen in months so whatever it was has probably been fixed.
I can tell you for sure that this battery fail save is working, but I do have the mAH value filled in as well.
So theoretically it should either trigger the failsave on a low voltage, or you have reached total capacity of the battery minus the set value (mAH failsave value)
In the clip I uploaded, you can see it gets triggered around 14:27 see
http://youtu.be/bwXqhHr-ieM
This time it activates the land mode because I am very close to the takeoff location.
If you are further away it will trigger an RTL, and for these reasons I have reserved battery Capacity (2000mAH), to be able to fly back, otherwise it may start dropping out of the sky somewhere out of reach...
I however have never tried to fill in just the voltage..,
Erik
it absolutely always worked with just voltage. what if I have multiple batteries of different capacity?
all I care is that it is a 4S battery and at 13.9V I need to do RTL. It does not happen in 3.3rc5. And it was working in 3.2.
I'm with you on that Paul. With three slightly different capacity packs I can fly with on any given day, including one after the other, I need to have Voltage Only triggering Land or RTL if I want it to.
So, no one can offer neither advice nor explanation of what may be going on with this feature? I tried all combination again today, made sure in the voltage sensor screen it makes an alert, I saw alert on the MP screen for low voltage, but still no sign of any attempt to initiate a failsafe by voltage level.
What is the deal with it?
Paul I did flight tonight and flew long enough to get a battery voltage failsafe trigger, so it's working for me. This was at about 50% of set capacity (using older packs that never get near capacity now)...
Martin, what do you mean by '50% set capacity' ?
What did you set into parameters? Did you put in a specific voltage level for failsafe to initiate or a percentage of a battery capacity? What condition triggered your failsafe event - capacity estimate or an actual voltage level reading?
Little off topic, but Paul, isn't 13.9V (3.475 per cell) a little too low?
I almost always finish my flight around 15V (3.75 per cell)
I even go for 3.3V/cell under load. You are perfectly safe as long as voltage/cell does not drop eveb for a short period below 3V - thats typically the threshold when permanent damage will occur.
334
335
336
337
338
of 449 Next
