Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
70% throttle to maintain a steady hover is incredibly underpowered. Something's clearly wrong. If you're confident that there's nothing wrong with the 'copter, have you tried a different LIPO?
hmm, it does not happen to me. it sometimes drops down from alt hold into stabilize if you did not have throttle leveled up to where it needs to be, but I just flew in both alt hold, loter, stabilize - did not drop down once.
I'm still flying 3.2 and after careful set up and calibration have zero error messages and it flies flawlessly. Perhaps if others simply want to fly without testing might want to just use 3.2 for now.
I would like to remind everyone that this is just a release candidate, not a full release. This is where we ask the wider community to give us feedback so we can address problems and bugs before we do a release.
So if you are flying a release candidate then you should not expect perfection. You should also not base your decision to return hardware based on release candidate warnings.
The Ekf is relatively new and we are still polishing it. Too many people are getting too many warnings for my liking and we don't have clear solutions to these warnings.
Please be patient as the devs are under a lot of pressure at the moment.
I would also like to apologise for the slow reply to some of you. I have been away for work and have not had time to reply as I am limited to my phone. I will be back on line in another 5 hours or so.
Leonard, I totally understand what you are saying here. I am very grateful, as we all are for the efforts of all the devs on this project - you provide an awesome service to all us enthusiasts, and we wouldn't be able to practise our hobby/profession(in some cases) without the awesome efforts you selflessly provide. I also appreciate the situation with beta code - I just raised the post here purely to ascertain if my issue was down to my own hardware setup or if it was something code related. As regards returning hardware - I wasn't considering doing this because of the EKF issues, but for the IMU2 Vcc filtering issue which is purely hardware related (just bought a second HK copy based on pixhawk and this also has the Vcc issue causing bad accel/mag health reports unless I first short the power cables before connecting battery).
Can I ask though - in order to take 3.3 and switch off EKF, returning it to the filtering methods of 3.2.1 - is it simply a case of setting EKF_CHECK_THRESH to zero?
Paul,
I'm afraid it's not possible to turn off the EKF in AC3.3. Reducing the EKF_CHECK_THRESH (renamed to FS_EKF_THRESH in -rc6) will just stop the failsafe from triggering and switching into Land mode.
We made the decision to drop inertial nav and DCM because the EKF had time and again shown itself to be superior especially when things went wrong. Sadly we've seen a couple of cases where EKF hasn't performed well but I think the answer is just to redouble our efforts to get it working well rather than hold onto the simpler DCM and inertial nav solution.
Hi Paul,
No problems and thanks for the kind words.
I am sorry but I am not sure if that would turn the EKF off.
If you look about 7 posts up, Craig answered this with the following:
The article basically suggests the simplest workaround being to connect a 4k7 resistor on the back of the power module between the 5v vdd output and ground. I will maybe try this when I have the chance to pull my hexa apart (power module is a bit buried on my hexa!)
@ leonard
I agree with them
I like the EKF in theory, but once in a while I hear "EKF Variance" spoken by the GC software I'm using. And about that time the Iris goes a bit "Blazing Saddles" on me and flys off in some totally random direction. I have CH7 set up to toggle EKF on and off. In those cases, I switch it off, wrestle it into submission, and it calms down. So I'm testing it, but I think I would probably be chewing through hardware at a high rate if I wasn't able to turn it off when needed. :-)
328
329
330
331
332
of 449 Next
