Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I'm sure it's something I have or am doing wrong,
Send a log file to Pix4d, they'll get you going again. Nothing worse than not being able to work. There's still a 90 degree kappa angle error when using Pix4d though. No big deal, again just don't select high precision if you're using 2.0 Pix4d mapper. Earlier versions don't matter.
What are you using to trigger the camera? Gent led and other ir triggers are problematic at best lol. I use direct multiport on a relay output, never miss. If you can't match them up and you're using Pix4d, their geotag function will work. If your geolocation is off, just don't select high precision. Won't effect your precision, it just takes longer to process.
Based on the numbers you list, there are 16 fewer images than triggers. This seems consistent with the behavior you have seen previously.
GlennM, replied over on your other thread but in short, it's probably that the SD card can't keep up. Try reducing the logging or replacing the card.
There is a patch for HoTT protocol support by Adam Majerczyk
I'm using HoTT for two years with APM and with PX.
Also there are some MAVLink2HoTT translators. I made one of them. It's firmware for Arduino micro etc. You can easily find it within this group.
care to share some links?bcs it is everything but easy do....also its not working with 3.3
https://github.com/diydrones/ardupilot/issues/631
https://code.google.com/p/hott-for-ardupilot/source/list
Yes, sorry we can't get all the requests. There are a limited number of developers and over 237 outstanding enhancement requests. ..and the number of requests grows faster than they can be completed.
telemetry to HOTT question is here since APM.....
131
132
133
134
135
of 449 Next
