Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • Hi Artem,
          I use 13x5 upper and 14x7 lower. Rcout is almost equal for upper and lower motors.
          3702802841?profile=original
          • 3702854085?profile=originalThx,  what is your AUW and motor  KV? Thank you!
            • AUW 2650g
              Pixhawk AC 3.3.2
              Neo M8N
              EMAX MT3506 650KV
              Kiss ESC 18/30 A
              Multistar 10Ah 4s 10C.
              Aeronaut Cam Carbon light 13x5 upper / 14x6 lower.
              ->26 min hover.
              I also tried APC Electric 13x4,5 / 14 x 7.
              Both Setups work fine. I think for an efficient coax setup you need more pitch and larger diameter for the lower prop.
              • Yep,  AUW is about what I thought. Thank you!
            • Everything I've seen tested so far is either from a test stand of hovering.  Like helicopters, once you start to move and enter ETL (effective transitional lift), a lot of the vortex interference will dissipate.  given the vortices travel downward, I wonder if mounting the rear arms higher than the front arms would help?   Sounds like a job for Simscale : )
              • Its a Y6, coaxial.
                • Then you'd just raise the single back arm.  Funny you'd mention a Y6, I was thinking of a Gryphon 1400 Y6 with a bent arm on the rear and 6 of the new KDE 8218's.
  • Any suggestions on improving noisy IPD EKF values? It appears that it is mostly related to a Noisy Barometer. I've got vibrations well below acceptable levels.
    The Pixhawk is housed in an rctimer dome.
    I loose about 5-10 feet of altitude transitioning from hover to directional flight. I've increased EKF ALT Noise to 3.7 and its subdued the rather aggressive drop to a sustained slow drop over about 10 seconds vs 1-2 seconds.
    Still would like to improve on this.
    2015-12-02 17-35-49.tlog.zip
      Kenneth,
      Looks like a tlog, if you've got a dataflash log I'll take a peek at it.  If it really is baro noise, then it's a known issue on the to-do list here but there's no guarantee we can do anything about it in software actually.  The best solution is a physical change to the frame.  Here's the diydrones discussion on this topic.
      • I think the issue you linked to is a "Climb" issue and his is a "drop" issue. I've always had a climb issue since back in the old APM days and not just APM but even my old MultiWii boards. And to be honest. I have always kind of liked it :)
