Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Thanks Hubertus for your reply,
Did a reset of the parameters, recalibrated acc and compass, but loiter is still taking off horizontally.
Here's a log of the same craft taken last year with an older firmware and loiter worked well. Maybe my larger MR isn't adjusting well to a new parameter or change in the code?
27.BIN
Compass orientation looks OK.
Do you have a log with the reset parameters?
Hi attached is log with reset parameters. I see the position innovations (IPN and IPE) go bad around the time I bail out of loiter. Little strange as it seemed out of control during loiter but it shows a low IPN/IPE. Then IPN/IPE goes bad (but is flying OK in stabilize)
1.BIN
Nothing strange in the log except the failing Loiter.
MR tries to correct position, but flies in the wrong direction.
The GPS quality (NSAT/HDOP) is not as it should be with a M8N. Only 9 Sats all the Time.
Perhaps you can try to configure GPS.
Thanks guys for the help on this.
Any website with a listing of the meanings behind the ublox uncenter parameters? I successfully connect to uncenter on this gps but I remember trying to upload that config file to a m8n gps last year and it bricked it and ended up buying a new one (current one). Still have the old gps but it didn't seem to respond after uploading the file.
Sounds like it either has the wrong antenna installed or it is only reading the GPS sats and not GPS+Glonass
But yah other than that the logs look pretty good. Vibs are decent. Voltage is decent.
After verifying that the ground station or aircraft compass matched a real compass in all four directions, east and west were also reverse, the machine flew correctly in loiter.
I felt really dumb when I realized it.
You might be on to something. I did switch GPS units on the offseason. Its this gps http://www.readytoflyquads.com/mini-ublox-m8n-gps-w-35x35mm-mountin...
I have it mounted as shown (with the ceramic antenna up). Wires going towards the back of the MR. I recall someone saying not to do the roll180 setting as the orientation changed from the old apm days, and all new gps were actually upside down but that was considered right side up. Or has that been my problem, not putting the rotation_roll_180 in the drag down menu?
i suspect all whitespy units are unsafe. 45mm gps unit ate battery i soldered in in fall over winter, and its gps is producing highly erratic data that causes vehicle to wander around. it is not charging battery and i am not going to solder in a replacement anymore. reading of sats also dropped from 18-20 down to 8-11, it correlates to responses from some other people. smaller 35mm unit seems to be getting more stable readings - vehicle is not hunting around that much with it as gps source but it is also reading 12-14 sats top, a m8n unit.
2
3
4
5
6
of 449 Next
