Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
              • M8N config
                • Sorry Leon, but the .ubx file didnt work out.
                  You need to save it as .txt (ublox ucenter , menu tools -> GNSS Configuration -> GNSS to file
                  please
              • Will do (once I get in to work ;) )
        • I agree that they vary in quality. I've had a very bad one and my current one (RCTimer) is excellent.
          I suspect the drift is down to the velocity noise which is supposed to be worse on these units. I think well designed attennas make a difference here, but net is that with patchy coverage performance will be worse than some of the older units.
          YMMV :)
          • I can corroborate good experience with the RCTimer M8N. In fact I just ordered a few more. cheers.
            Rctimer NEO-M8N GPS & MAG(Compass) V2.1_Rctimer R/C Hobby Online Shop
            Rctimer NEO-M8N GPS & MAG(Compass) V2.1现价39.990; M8N Tutorials:  Multi Constellation GPS (
        • I've got two copters with them now.  One is from HK, and the other is from readytoflyquads.  The mini M8Nv2.
          HK gets a few more sats, but I think that's due to the layout of my copter (650 vs 250).
          Both have the same behavior.  Great in the clear sky, but jumps around more than previous GPS when lower to the ground.
          It's raining now, so probably not a good time to get a log.. But, I can certainly make one.  I simply have to arm it outside and let it sit stationary, and we can see MP thinks it's drifting all over.
          I'm not all that concerned, since it's ok high in the air.  Maybe I'm expecting too much, and am unlucky that my flying/testing ground has a few trees.
      • I've had very good results with the M8N on both a copter (3.3 rc5) and a fixed wing (3.3.0). My quad loiters with (at max) a 50cm drift in any direction.
        I have experienced the drift you describe above, but only when I've been inside or amongst tall buildings (both times the quad stationary and on the ground), but I attribute this to not having a clear view of the sky for the antenna.
        • Well, I should have been more clear in my description..
          Or at least added, the copter is very still when it is up above the trees.  I don't notice much drift at all.  But, down among the trees with a patchy view of the sky, I still have over 15 satellites and a low HDOP, (below 2 with the old pre rc8 hdop numbers) but the copter drifts all over as I described.
          The old copter with lea-6 didn't drift as much in the same location, with fewer sats and higher hdop..  Sparsely wooded..  Clear sky directly above, but trees nearby.. spaced apart enough to comfortably fly around them.
          • that is why a best design is to use 2 GPS devices and use 1 m8n and one lea-6 on the same vehicle.
            As Randy stated an effort will apparently take place to minimize position adjustment when one GPS switches with an another dynamically. As of 'jumping' coordinate from same single GPS - it is a different issue, probably.
          • Now I think that is different.
            I never tried to run an M8N near a tree or above a tree.
            I always used M8N in the clear sky.
            So, maybe what I have written before is no loger valid =P
