Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
                • A while back on APM controllers the stack would sometimes see the USB as connected even when it was not. Kev went so far as writing in a detection for this event in his Log Analyzer but I haven't seen this happen in months so whatever it was has probably been fixed.
        • Hi Paul,
          I can tell you for sure that this battery fail save is working, but I do have the mAH value filled in as well.
          So theoretically it should either trigger the failsave on a low voltage, or you have reached total capacity of the battery minus the set value (mAH failsave value)
          In the clip I uploaded, you can see it gets triggered around 14:27 see
          http://youtu.be/bwXqhHr-ieM
          This time it activates the land mode because I am very close to the takeoff location.
          If you are further away it will trigger an RTL, and for these reasons I have reserved battery Capacity (2000mAH), to be able to fly back, otherwise it may start dropping out of the sky somewhere out of reach...
          I however have never tried to fill in just the voltage..,
          Erik
          • it absolutely always worked with just voltage. what if I have multiple batteries of different capacity?
            all I care is that it is a 4S battery and at 13.9V I need to do RTL. It does not happen in 3.3rc5. And it was working in 3.2.
            • I'm with you on that Paul. With three slightly different capacity packs I can fly with on any given day, including one after the other, I need to have Voltage Only triggering Land or RTL if I want it to.
              • So, no one can offer neither advice nor explanation of what may be going on with this feature? I tried all combination again today, made sure in the voltage sensor screen it makes an alert, I saw alert on the MP screen for low voltage, but still no sign of any attempt to initiate a failsafe by voltage level.
                What is the deal with it?
                • Paul I did flight tonight and flew long enough to get a battery voltage failsafe trigger, so it's working for me. This was at about 50% of set capacity (using older packs that never get near capacity now)...
                  • Martin, what do you mean by '50% set capacity' ?
                    What did you set into parameters? Did you put in a specific voltage level for failsafe to initiate or a percentage of a battery capacity? What condition triggered your failsafe event - capacity estimate or an actual voltage level reading?
            • Little off topic, but Paul, isn't 13.9V (3.475 per cell) a little too low?
              I almost always finish my flight around 15V (3.75 per cell)
              • I even go for 3.3V/cell under load. You are perfectly safe as long as voltage/cell does not drop eveb for a short period below 3V - thats typically the threshold when permanent damage will occur.
                • I go down to 3.3v per cell as well. It is perfectly fine to me under load. Going 3.5v per cell is also okay but anything more than that is a bit too conservative to me.
                  Obviously when I give my answer I consider one will land soon after the 3.3v per cell is triggered. If you plan on flying for minutes or are far away from home then you will definitely need to consider higher voltage values here.
DIY Robocars via Twitter
Jul 4
Jul 4
Jun 25
Jun 25
Jun 16
Jun 13
Jun 13
Jun 13
Jun 7
Jun 7
May 28
May 15
May 14
May 13
May 13
May 11
