Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
So far I have seen IMU issues with: RTF Hawk purchased in August 2014, HK Hawk purchased in February 2015, ***** Hawk 2.6 purchased in May 2015. This is my exposure to the clone hawks through friends and people I've built copters for. I guess their manufacturers just changed the silkmask on the board and nothing else :) . regarding crazy amount of chatter : it was noisy back in December-January and 3DR got involved and figured out that there are 2 causes IMU1 was their problem and IMU2 was cloner's, so they swapped real 3DR pixhawk boards and sent all others to the manucturers of the clones. If you red RCG thread about rtfhawk and the HKhawk as well as the HK Hawk discussion page on the item's website you will see a lot of people are having this issue.
Hi Paul,
First up it is a bit hard to see what is going on. If you could use the log mask of 419837 that would be great.
So what has happens is the copter thinks you are flying aggressively so it doesn't think you have landed. But because you haven't flipped on your back it hasn't detected a crash.
Randy and I have been talking about this and will fix this issue tomorrow.
Thanks for your help!!!!
And sorry for the dangerous situation!!!!
Leonard, always appreciate your input and great efforts in developing this awesome project. Thanks for getting back. Best wishes, Paul
It won't disarm in AltHold if it thinks its flying - I believe this only works in stabilize. Rob has suggested (or maybe it was me and he agreed, I forget) that perhaps it should allow disarm if throttle is at zero in AltHold type modes, it would mean that yaw would be ignored if you were descending but I personally think that's better than the status quo. Right now if you want to be sure to disarm you must switch to stabilize first.
I'm almost certain I have disarmed after landing in AltHold mode before (and definitely have in PosHold many times. It seems to be an omission if this is specifically designed not to allow disarm in AltHold once the copter is on the ground. I'm a little confused by your comment - Just wondering why it would think its still flying (you said it won't disarm in AltHold "if it thinks its flying"). Cheers, Paul
RIght it works if the copter thinks it has landed. If it doesn't think it has landed then it will interpret right yaw at zero throttle as right yaw descending rather than as disarm.
OK, so if this is not an obvious question - why did my copter think it hadn't landed? Maybe this is the real issue which needs understanding.
I believe its a difficult problem. For me 3.2.1 was a lot worse than 3.3 in this respect. 3.3 is still not perfect but I find it to be pretty accurate.
I think yest, vortex can distort baro reading, but I am using rangefinder and when rangefinder reading is 0, throttle 0 no movement (gyro) I would expect that status interpreted as landed...
Has this got something to do with the vortex of high pressure created by the props as they near the ground? I read something about this elsewhere.
352
353
354
355
356
of 449 Next
