Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • Hi leonhardthall,
            Thanks for your support (and all others).
            Should batmin be lower then 14v?
            What does it mean?
            I test in next days. Actually it's too much wind.
            And the function is similar like the method of the old variant of esc calib?
            The reason is, i want use thethe much better autotune values on 3.2.1 till 3.3 is stable. I have fear because of fly away or crash.
            And another questions of log. Which bitmask should i use. The logs actually are so big.
              Hi Speedy and Paul,
              The MOT_XXXXX parameters i am talking about here define the throttle curve to keep the trust linear. The code then adjusts for throttle position, the dead band at the top of the throttle range, and the battery voltage. The throttle/thrust curve is applied to each motor.
              If set right this stops high throttle oscillations and reduces the decent wobbles. It also ensures that auto-tune done at the end of the battery doesn't produce a tune that is too high.
              • What is the optimal bitmask for logging?
                And should batmin at 4s lower than 14V?
                  Hi Paul and Speedy,
                  The bat min is just there to define the maximum increase in gain you can have. So it doesn't have the be lowest value it can reach. I use 4.2 x cell count for max and 3.5 x cell count for min.
                  For good quality stiff props (mainly at the smaller diameters) I use
                  % 0.65 is for 5" props
                  % 0.65 is for 6" props (I think the low numbers come from flexing props and I use HQ and they are stiffer than normal)
                  % 0.675 is for 10" props
                  % 0.725 is for 11" props
                  % 0.75 is for 12" props
                  % 0.75 for 16" props
                  % 0.75 for 18" props
                  for Mot expo.
                  • Hello leonardthall,
                    yesterday we had a morning without wind. so i made a new autotune test with the recommened throttle curve. i think yaw tuning is perfect. it´s so smooth. i like it really.
                    but in pitch and roll i´m not so sure. the feeling is good, but i think, theres wobble at higher speed, too. so i´m not sure, if i have mechanical problems or is there a generally pid proplem.
                    the different to pids without throttle curve are little bit higher rate p pitch and lower (half) stab p pitch.
                    attached in dropbox are 3 logs...autotune roll/pitch, autotune yaw, and a normal flight.
                    https://www.dropbox.com/s/empifgouc5xr2gs/normal%20flight.bin?dl=0
                    https://www.dropbox.com/s/odsk0tmce1p8k6l/roll%20pitch%20autotune.b...
                    https://www.dropbox.com/s/3p8yq8gjx5xe8yq/yaw%20autotune.bin?dl=0
                    edit: at autotune i had sometimes fear. three or four times it looked like he would fall down, almost flip...but then in was stable again and autotune finsihed correctly.
                    Dropbox - Error
                    Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
              • Understood. How do we set _expo parameter depending of prop size? Is there a formula?
          • HI, I just noted on both my systems
            MOT_THST_BAT_MAX and MOT_THST_BAT_MIN are set to 0.
            other 2 are
            MOT_THST_EXPO,0.5
            MOT_THST_MAX,0.95
            And both systems fly just fine.
            What is the rule of thumb here, should those 2 first ones always be set manually to correct voltage levels? If I start from 16.8 and go down to 13.5v - should that be used?
            How prop size affects those parameters?
              This gives you a good idea.
    • ...a copy of my reply to Randy:
      Hi Randy,
      In X2, the VBUS_VALID is not connected to the PC0 as we don't have 4417.
      As the USB VBUS signal is connected to PA9 of the STM32F427VIT6, there are two reasons the MCU detects it is still present:
      1. Either PC0 is floating ...without any pullup/pulldown programmed and the firmware doesn't care of PA9 at all, or
      2. the PA9 is without pulldown programmed and the VBUS 100nF capacitor is not discahged and the system reads it as 1.
      If I understand the situation right, adding a pulldown to PC0 and PA9 + some code to check the VBUS status could solve the problem.
      Best regards
      Nick
  • Today I had my first crash where I think it was not my fault.
    I changed my Transmitter from Jeti to Taranis. The first short flight was ok but the Nick was reversed. After reversing the Nick I started to the second Flight as suddenly the Copter went to the right and crashed.
    I´m not 100% sure if it is a failure from the Taranis or from the IMU. Please can you have a look at the Log?
    I looked at the Log and saw the the desRoll and roll is different but I´m not familiar with reading logs.
    Thanks a lot André
    2015-07-03 16-59-50.bin
