Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Wilson,
Sorry, I actually downloaded your log when you first posted but didn't complete the analysis.
I think the lean is caused by the poor GPS location. The NSat is really very low at only 5 or 6. I think the GPS position was drifting around but it wasn't bad enough to trigger the glitch protection.
The EKF also reports a spike in velocity and position variances around that time. I'm not very familiar with the units of these variances so I've asked Paul Riseborough (EKF expert) and we shall see what he says.
I don't think it's caused by the low battery itself because the desired and actual roll/pitch values stick together.
Wilson,
Yes, when the failsafe triggers it will try to use the GPS unless it's had an EKF/GPS failsafe. So the GPS position must be quite bad for it not to use it. In your case this is not great because the battery failsafe triggered a GPS controlled land while the GPS quality was not great because (I guess) it was descending in the shadows between buildings. It's a bit tricky to handle this case.. I think we would need to tighten up on the GPS requirements but that could cause problems in other areas like when we set the home location or do the pre-arm checks. I'll discuss with the dev team but I don't immediately have a solution.
RC10 has something changed again in the GPS department I guess as I flew it today and it was very erratic compared to rc9. RC9 was almost ideal, this RC10 flight today was nothing like it.
with rc9 I did not have anymore HDOP 0 or 99.99 issues - with RC10 I had 99.99 stuck HDOP on first GPS unit for 3 power-ups consequently, plus during flight drone was wondering from location to location way more aggressively than with rc9. may be it was a solar storm today, who knows, but I kinda doubt it as with rc9 on same field I always had RTL to return within 50cm from the take off point, and today RTL did a wild hunt for landing spot with a 20m arch going left and right at aggressive angle, so I had to drop drone down to the grass which I did not have to do once since rc5.
so it was a bit unexpected. Did you by any chance reverted GPS code from RC9 into old from RC8 as Rc8 used to behave like that.
here is log file. Both GPS units were from 20 to 19 sats with good link from what I can see, overall vehicle attitude was horrible compared to hw RC9 behaved, it was constantly jerking from one position to another, so, I bet something was altered.
If there is a plan how to make it work better I think it has to be a priority now, as it was close to unusable today and for no obvious reason.
here is a link to log file.
https://www.dropbox.com/s/ypsdkieixdp4blf/20.BIN?dl=0
Others on RCgroups have given similar reports.
I would suggest you try it a few more times and see if some days are better than others.
Paul,
Yes, totally agree that disabling the 2nd GPS is not the ideal solution. It's on the to-do list to fix for AC3.4 so I'm sure we will sort it out in the coming months.
Paul,
I just reviewed the commits and as far as I can see we haven't made any changes to the GPS code between -rc9 and -rc10. Just in case anyone wants to check (now or for future reference) the list of commits can be seen here and the changes in -rc10 are all the things after the "Copter: version to AC3.3-rc9" commit. The first part of the description describes the area of the code change and there's no "GPS:" changes.
I've looked at the logs and, like you, I also see the constant changing back and forth between GPSs (see "U" field in GPS and GPS2 messages) which we know leads to ugly shifts in position although I don't directly see the impact of these shifts on the EKF innovations or vehicle lean angles. Still, to be honest, it's the first time I've really looked for them. I suspect you're right that this is the cause.
So a couple of suggestions/comments:
A correction to the 3rd point. I checked with our GPS maintainer, Michael DuBreuil, and as Josh Welsh says, the baud rate is being set back to 38400 so it won't help to change that with u-center. Sorry!
Michael also suggested that Paul Atkin may want to disable SBAS (i.e. set GPS_GNSS_MODE to "1") because based on you location you could be picking up a WAAS satellite from very far away.
Josh,
The GPS driver starts at 38400 but it does try various baud rates if it doesn't find a GPS. I've never tried it myself to be sure but Tridge and Michael DuBreuil who know more about the GPS driver tell me this.
Hey Randy,
I thought on boot, the autopilot was setting the gps's baud rate back to 38400, regardless of what was already set via uCenter. Is that not accurate? I'm very likely mistaken, but don't know how to read the code well enough to verify on my own.
Josh
187
188
189
190
191
of 449 Next
