De-shaking, editing frustrations gopro.
Hi.
There must be thousands of people doing exactly what I am trying to do so am seeking advice here.
What I would like to do-
-Download the MP4 from my gopro (hero3, using 1080p 5-fps at the moment).
-Use some software to reduce the shakes.
-Perhaps trim/join add music etc.
-Save in a format of my choice.
Where its going wrong-
-Im using virtualdub with deshaker. Seems to be quite good and I expect I can improve the settings.
There appears to be no choice to save except AVI. It is saving an AVI file 10x the original MP4 size. WMP will play it but most other editing stuff gives errors.
-Handbrake says its a protected file.
-VLC says CFHD ‘no way’.
-Mercalli V2 stops halfway and closes down.
What did I do before computers?
Any advice welcome.
  • There is a workflow required for Virtualdub deshaking and you are doing on a few of the steps. These are what we do:
    1. Convert the video to divx or avi raw from out-of-camera format using WinX HD Converter.
    2. Run Virtualdub/Deshaker process with pass 2 output to raw AVI
    3. Convert from raw AVI to MP4 (or whatever works best with your editor of choice).
    4. Edit the video in Premier or After Affects.
    5. Encode using Adobe encoder to final video format for publication or upload.
    FWIW, all the cache files for all adobe products and Virtualdub are on SSD drives. This takes a while to do but using SSD helps a LOT. Also, all of our editing systems are i7-980x or 2011bus systems with 18+gb ram. Virtualdub will run in 4gb (barely) but After Affects won't.
    Good luck, JAZCAM
  • the best result I obtained with Virtualdub is when no part of heli or plane is visible on the movie.
    If you have visible parts from heli or plane (motors and props, wings, etc), Virtualdub deshaking process will try to make those static objects as reference and the process will not have the best result. Try first to crop the movie to hide the static objects (heli or plane part) and then apply the deshaking process.
    See below one of my test with Virtualdub with a diy quad h-frame with  GoPro Hero2
    https://vimeo.com/55280289
  • Just got one uploaded
    Hi Vince,
    Here are my 720P processing files for Virtual Dub and Deshaker and the Barrel distortion filter to remove the fish eye.
    It is a two pass process that then saves at the end. You can use other codecs to compress the video as well. I use the K-Lite codec pack. There are some issues with some compression techniques that VirtualDub can't use because you must pay for them.
    This video shows the results I achieved.
    https://www.youtube.com/watch?v=EDKlv6yVtxA
    GoProProc1.vcf
    GoProProc2.vcf
