DJI Phantom Pixhawk Build
I am currently planning to build a PixHawk powered Phantom. I know this has been done before in some regards, but I wanted to share my process and build as I move forward. Here is the list of parts and links:
My plans for this build are to make it look like a custom DJI Phantom and keep it clean. The Main plate that he sells is a completed power distribution board, an integrated Power Module for the APM/PixHawk, and additional uBEC to power 5V and 12V accessories.
Below os a stock photo not the one I am building.
  • Thank you. I'll try this pin layout.
  • I have one of these PDB boards and it won't supply power to my Pixhawk through the PM port. You mentioned that the pins were reversed. What did you mean by that? Which pins are reversed? Do you have a diagram of the proper pins?
    • Match the pinout here to the labels on the the distribution board. I hope that helps
  • Ok, So the build moved along nicely. The only snag I hit was the PDB's built in PM. The pins are reversed. Pay close attention to the pins before powering up. Never rely on wire colors. Anyways. Here is the final layout and the Param file after an autotune.  I ended up with the 4200 multi-star batteries and they seem to give my decent run time. I will also experiment with 4s batteries.
    I still have a few more things to accomplish such as,
    • Installation of a gimbal
    • Video Transmitter
    • DJI Transmitter
    Other then that. I am happy with the results. Now I need a Phantom case. ;)
    3701976609?profile=original
    3701976435?profile=original
    3701976645?profile=original
    PixHawk Phantom Param.param
    • i just ordered my parts to make a phantom, then i found you were doing something similar
      pixhawk lite
      nano minimosd 2g
      1g 200mw vtx
      walkera x350 esc's
      walkera g3d gimbal
      5200 multistar
      clone phantom 2 motor and props
      Lidar lite
      PX4 flow
      for this build weight is my main priority, i want to get as close to 20 mins as possible so every gram counts.
      what kind of flight time are you getting?
  • I just of some of my parts in. 3701975049?profile=original3701975057?profile=original3701975112?profile=original3701975166?profile=original
    • Your build looks beautiful, and is very close to the build I'm planning.  I've made an F450 clone using a mini APM, but am hoping to use a Pixhawk with the stock 3DR GPS/compass on this one and had a few questions on your build.
      1) Did you mount your GPS inside the shell, and if so, a) where, and b) how is the reception?
      2) I'm planning to use the basic $4.50 mainplate (which seems to be just a PDB) and 3DR's power module.  Are there wiring instructions that come with the mainplate you bought?
      I'd love to see a photo of the inside of your final build - it looks awesome!
  • Have u managed to get this sorted?
    • No luck with this thing.  the esc's just keep beeping beep, beep, beep, I'm assuming it has something to do with calibrating the esc's to the pix hawk but cant figure it out.  Post that I've seen all say phantom esc boards cant be calibrated.  Any advise would be helpful
  • I have mine hard wired but doesn't seem to get power and it keeps beeping I'm guessing cause of that port.
