I am currently planning to build a PixHawk powered Phantom. I know this has been done before in some regards, but I wanted to share my process and build as I move forward. Here is the list of parts and links:
RTF OPERA QUAD FRAME (DJI Clone)
- OPERA FULLY POPULATED MAINPLATE "PHANTOM CONVERSION KIT"
- T2212-980KV RTF MOTOR
- RTF "PHANTOM" OPERA ESC 20AMP
- HQ PROP 9X4.3 CARBON COMPOSITE PROP
- 3DR PixHawk
- External USB and LED
- 915Mhz Telemetry
- u-blox GPS and Compass
- Tarot 2D Gimbal
- GoPro Hero 3+
- 5200 3s Multistar Battery
My plans for this build are to make it look like a custom DJI Phantom and keep it clean. The Main plate that he sells is a completed power distribution board, an integrated Power Module for the APM/PixHawk, and additional uBEC to power 5V and 12V accessories.
Below os a stock photo not the one I am building.
Hi, I am also able to make this phantom 2 configuration with pixhawak 2.4.8 .... I wanted to ask you if there is phantom in the pix 2.4.8 .......... I need to have some tricks for let her stay inside the phantom
Russell Nelius said:
UAS_Pilot Helo, How is the update on this project ? Any recent improvements...
we are professional bldc motor used for Drones, UAV and Quodcopters, Crazy motor is the symbol of high quality and stable performance, mroe info, please find in our website:
http://www.crazy-motor.com
This build is killing me. For the life of me I cannot figure out how to get the esc/motor's to respond after arming. Pixhawk is reading the outputs from my taranis correctly, the safety switch is working, the pixhawk is arming, but the motors will not spin up. I've tested each esc with a servo tester and they work fine with the servo tester but when I hook it back up to the pixhawk i get zero response. Please help!!
You'll notice that only two of the servo leads are hooked up to pixhawk for the motors... that's because in frustration i ruined the signal pads on two of the esc's...
I'm also planning on one of these. Will a genuine Phantom 2 shell be sufficient? RTFQ doesn't have a helpline...
Hello again. I received the plate and my question now is the function of the USB ports. I have seen that are connected between them, but nothing more . a greeting
The quality of the Opera plastic is, I hear, very poor. The screw threads do not even stand up to multiple fastenings I have read. Will the Opera main plate fit into a genuine Phantom 2 shell. If it can be made to work that is what i would do.
Also, you may want to look at a Pixracer board. It is smaller and has built in wifi (not yet working for Arducopter but I trust it will soon).
HI, we can used 4S battery whit this mainplate?
Yes, I used 4s batteries in my setup. Worked fine.
