Hello pilots! I am new and want to build my first quad copter, but I am not sure about the ESC, Motor, Propeller on my part list. I also do not know which battery pack and battery charger I need to fly between 10 and 20 minutes with my setup. Please give me advise about the parts, if you think there is a better alternative or if I forgot a part. Thank you!!
MultiWii PRO 2.0 Flight Controllerhttp://witespyquad.gostorego.com/flight-controllers/multiwii-pro-2-0-flight-controller-200.html
Q450 Glass Fiber Quadcopter Frame 450mm - Integrated PCB Version http://www.hobbyking.com/hobbyking/...opter_Frame_450mm_Integrated_PCB_Version.html
NTM Prop Drive 28-26 1350kV * 4 http://www.hobbyking.com/hobbyking/store/__21479__NTM_Prop_Drive_28_26_1350KV_302W.html
Slow Fly Electric Prop 8045R * 4http://www.hobbyking.com/hobbyking/...ctric_Prop_8045R_4_pc_Green_RH_Rotation_.html
Slow Fly Electric Prop 8045SF * 4http://www.hobbyking.com/hobbyking/store/__22438__Slow_Fly_Electric_Prop_8045SF_4_pc_.html
TURNIGY Plush 25amp Speed Controller * 4http://www.hobbyking.com/hobbyking/store/__2163__TURNIGY_Plush_25amp_Speed_Controller.html
TURNIGY BESC Programming Card http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=2169
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC)http://www.hobbyking.com/hobbyking/store/__68__PolyMax_3_5mm_Gold_Connectors_10_PAIRS_20PC_.html
Power Harness
Lipo battery
Battery charger
Hobbyking 2-8S Cell Checker with Low Voltage Alarm http://www.hobbyking.com/hobbyking/...2_8S_Cell_Checker_with_Low_Voltage_Alarm.html
Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2 Firmware) http://www.hobbyking.com/hobbyking/..._Module_8ch_Receiver_Mode_2_v2_Firmware_.html
Hi Shahin,
How did this assembly go? Faced any issues. Is there any significant change in the list you suggested?
I am asking because I am interested to build a similar frame.
Hi Mohamed,
There was one drawback. The multiwii pro 2.0 was a disaster and GPS did not work no matter what I did. I bought the DJI Naza V2 with all the other parts the same as the list above and it was perfect! It flies perfect and I LOVE it. Two video's of the new system flying:
https://www.youtube.com/watch?v=wwZ62udFcVs
and
https://www.youtube.com/watch?v=CcWxnxagADE
Good luck and have fun :D
This is the new parts list:
HobbyKing™ Lipoly Low Voltage Alarm (2s~4s)
Don't use this low voltage alarm from HK. It caused my quadcopter to crash because the battery alarm did not turn on when the battery was almost empty.
I bought one from somewhere else where you could setup your own minimum voltage.
Thanks for the reply. How much was the flight time when fully loaded, and fully charged?
I have another question. Have you tried to fly a good smaller quadrotor size?
Almost 15 minutes. It depends on how fast I fly, the faster I fly, the faster the battery is drained. I've not flown any smaller quadcopters yet.
So guys, I finished making my list, I think;
Quantity
Stock
Product description
Price
Weight
2
OK
N2200.4S.45 - Turnigy nano-tech 2200mah 4S 45~90C Lipo..
EU40.69
626
1
OK
ACC6 - Turnigy Accucel-6 50W 6A Balancer/Charge..
EU17.70
437
1
OK
9052000014 - Hobbyking 60w Power Supply
EU7.69
407
1
BK
Voltage-Alarm - Hobbyking 2-8S Cell Checker with Low Vol..
This item is on backorder*
EU2.93
23
1
OK
TX-9X-M2 - Turnigy 9X 9Ch Transmitter w/ Module & 8..
*This item usually ships within 3 days
EU41.44
1375
4
OK
9045000001-0 - MT2213-935KV MultiStar Motor and Propell..
EU45.06
676
1
OK
9387000028-0 - Multiwii MWC FC Bluetooth Module Program..
EU5.77
19
1
OK
387000003 - MultiWii PRO Flight Controller w/MTK GPS..
EU50.04
78
1
OK
TR_PC - TURNIGY BESC Programming Card
EU21.28
200
4
OK
TR_P30A - TURNIGY Plush 30amp Speed Controller
EU40.44
220
2
OK
297000029-0 - Q450 Glass Fiber Quadcopter Frame 450mm ..
EU19.30
790
1
OK
BOX-183g - Extra Size Cardboard Box and Packing 183..
EU0.00
183
1
OK
AM1001A - PolyMax 3.5mm Gold Connectors 10 PAIRS (..
EU1.30
30
1
OK
WH-4MM-BLACK - Turnigy 4mm Heat Shrink Tube - BLACK (1m..
EU0.54
38
1
OK
WHS-4MM-RED - Turnigy 4mm Heat Shrink Tube - RED (1mtr..
EU0.54
38
TOTAL: EU278.76
4990g
total incl. shipping: +- EU350
Regards, Soren
Your propellers are a bit small. Why not go for 10x4.7 or even 11x4.7. Larger props require lower engine rpm and result in less battery.
Alot like my build , U used the Q-brain ESC 25 amp, and the HK power module from hobby king, running a 4500 Mah zippy compact battery. Also buy a couple of the frames when u crash you will need spare parts and there so cheap. I made the mistake of not ordering 2 then I had to wait for my new frame to arrive..... I'm using this motor "Motor prop combo" with props and is close to the stock DJI flamewheel 450 motor and prop combo seems like its working ok for me no problems yet and a fair price.
