Hi ALL
We are developed low cost controller named F4BY.
project members
Maxim Strinzha - Programmer
Sergey Lipnickiy - hardware designer and programmer
Alexey Kozin - dedicated to the popularization and promotion, technical support.
Hardware details
APM2 classic sensors set + STM32F407 + sd card + fram
one board , two layers, 50*50mm size
We did software HAL layer and tested it with firmware ARDUCOPTER 3.3.2 and Arduplane 3.4.
Hardware and software has been tested in a test flights, everything is fine.
We would like to integrate the project into a common repository Diydrones.
The current software version is here https://github.com/swift-flyer
we are ready to provide open hardware circuit board in case it is needed.
I wonder whether such integration Diydrones and what you need from our side for this integration?
F4BY set
experimental samples
first tester)
mounted at 250 frame
250 frame pid settings for littlebee 20a + damped light here
good fly any wind and turbulence tested at 2 different copters 250 size
FPV video
discussions
http://forum.rcdesign.ru/f123/thread456525.html (RU)
http://forum.apmcopter.ru/threads/kontroller-f4by-2-x-x.100/ (RU)
interfaces F4BY:
5 USART (one inverted)
1 SPI (free hardware port)
2 I2C (external i2c1 - full access, internal i2c2 not available to the user)
1 CAN
4 external ADC input
2 internal ADC
3 GPIO pins available
8 PWM outputs
8 input-output PWM (supported input PPM, PPM-Summ, DSM, S-BUS)
1 access to the beeper (PWM)
1 input sonar connection (either a timer or interrupt 9-5)
eagle schematic f4by v2.1.5 here
any questions here or kozin@mail.ru
Love It. ( I'm a stm32 fanboy :) )
Is there a spec, such as number and type of ports (USART, I2C, CAN, SPI Servo outputs SBUS options, ADC) etc etc.
I would hope that a schematic will be made available if you want it to have official support. Closed source hardware would make it a non-starter for me. Would be nonsensical surely
classic apm2 sensors
-mpu6000 gyro accel
-ms5610 baro
-hmc5883 compass
we plan to set the value for the end user $ 65, but are ready to send developer samples for cheaper then IC set cost
I would like to test one. Can you tell me the way to get it?
send me email kozin@mail.ru .
I will send in response to your mail paypal invoice
Also, for new hardware we require that you provide a person who is the maintainer for when people have questions about it we can forward them to you.
