Hi ALL
We are developed low cost controller named F4BY.
project members
Maxim Strinzha - Programmer
Sergey Lipnickiy - hardware designer and programmer
Alexey Kozin - dedicated to the popularization and promotion,  technical support.
Hardware details
APM2 classic sensors set + STM32F407 + sd card + fram
one board , two layers, 50*50mm size
We did software HAL layer  and tested it with firmware ARDUCOPTER 3.3.2 and Arduplane 3.4.
Hardware and software has been tested in a test flights, everything is fine.
We would like to integrate the project into a common repository Diydrones.
The current software version is here https://github.com/swift-flyer
we are ready to provide open hardware circuit board in case it is needed.
I wonder whether such integration  Diydrones and what you need from our side for this integration?
F4BY  set
fullset_f4by_small.jpg?height=298&width=400
experimental samples
50pcsf4by.jpg?height=352&width=400
first tester)
miha_fyby.JPG?height=395&width=400
mounted at 250 frame
250 frame pid settings for littlebee 20a + damped light here
good fly any wind and turbulence tested at 2 different copters 250 size
FPV video
https://youtu.be/BNikGT8YnEk
discussions
 http://forum.rcdesign.ru/f123/thread456525.html (RU)
 http://forum.apmcopter.ru/threads/kontroller-f4by-2-x-x.100/ (RU)
interfaces F4BY:
5 USART (one inverted)
1 SPI (free hardware port)
2 I2C (external i2c1 - full access, internal i2c2 not available to the user)
1 CAN
4 external ADC input
2 internal ADC
3 GPIO pins available
8 PWM outputs
8 input-output PWM (supported input PPM, PPM-Summ, DSM, S-BUS)
1 access to the beeper (PWM)
1 input sonar connection (either a timer or interrupt 9-5)
eagle schematic f4by v2.1.5 here
any questions here or kozin@mail.ru
  • eagle schematic f4by v2.1.5 here
    Love It. ( I'm a stm32 fanboy :) )
    Is there a spec, such as number and type of ports (USART, I2C, CAN, SPI Servo outputs SBUS options, ADC) etc etc.
    I would hope that a schematic will be made available if you want it to have official support. Closed source hardware would make it a non-starter for me. Would be nonsensical surely
    • classic apm2 sensors
      -mpu6000 gyro accel
      -ms5610 baro
      -hmc5883 compass
    Do you have any further details on the hardware? For example what "classic sensors" did you use? Also, do you have a price? How can it be purchased?
    • we plan to set the value for the end user $ 65, but are ready to send developer samples for cheaper then IC set cost
      • I would like to test one. Can you tell me the way to get it?
        • send me email kozin@mail.ru .
          I will send in response to your mail paypal invoice
    To get it integrated integrated into upstream, you must rebase your branch on to master then create a new pull request and we will evaluate it and give you feedback. Once we are happy with it we will merge it in. https://github.com/ArduPilot/ardupilot/pulls
    Also, for new hardware we require that you provide a person who is the maintainer for when people have questions about it we can forward them to you.
    ArduPilot/ardupilot
    ArduPlane, ArduCopter, ArduRover source. Contribute to ArduPilot/ardupilot development by creating an account on GitHub.
