How to assemble with new diode?
I just received my APMv2 board from 3DR I purchased an un-assembled one so I cna use the right angle headers, but with it came two diodes (i think) one of the being a zener diode and I dont know where to solder them onto.
I would appreciate some help on where I should solder them.  I contacted 3DR help but I am still waiting for a reply which usualy takes a long time ;-(
THanks!
    Here are instructions on how to solder the new diode and fuse onto your Ardupilot Mega 2 board.
    Firstly you will get 2 components with your board.  A pico fuse (top), and a zeren diode (bottom)
    3692459752?profile=original
    The fuse you need to solder onto your power input to your APM (either your ESC wire, or from your PDB if you are flying an arducopter)
    3692459720?profile=original 3692459769?profile=original
    Its a good idea to put some heat shrink over that to avoid shots.
    Next you must solder the zener diode onto your ardupilot mega board.
    3692459584?profile=original
    3692459782?profile=original
    The diode is soldered onto your 5V and GND of the APM2 OUTPUT rail as shown above.  Make sure its connected the correct way around
  • Three weeks ago I assembled my un-assembled APM2. No Diodes, repeat.. there were no diodes in the kit.
    I did receive *jumpers* for header pins that are used if you choose power options for on/off the APM2 board.
    I did receive single pins for the mounting the onboard GPS module.
    Alex, you say "but with it came two diodes (i think) one of the being a zener diode"
    It is true that there is not much assembly instructions for the 'kit'. Here is what I received:
    3692458697?profile=original
    Is what you received the same as the picture above?
    Doug
  • Please share here if you got the answer from Tech support team.
  • I just came to post the same thing... Just assembled my board and there are no instructions about where to put these two components.
