Hi all,
I have problem with configurations of the switches:
http://pixhawk.org/users/system_modes
In mission Planner:
Now only one switch work, everything is calibrated(all switches).
So with graupner mx-20 and gr-24, how to configure PIxhawk flight modes?
I read something for switch 5, but I don't understand nothing.
  • Hi again,
    now I have problem with the channels:
    The RC is in airplane mode, and stick mode 1.
    The controls are:
    - the left side of the RC are the throttle and yall;
    - the right side are the roll and pitch.
    The problem are the roll and pitch - THE CHANNELS ARE REVERSED.
    - When I put forward i go to right, when i pull back, go to left. :(
    What can I do?
    • RTFM, then reverse the channels. :)
      You should try to open the manual, the radio offers many nice features you'll never discover unless you spend some time with it.
      • Hi,
        I am writing because I couldn't find them.
        There is a section in the manual:
        -Joystick setting:
        Detail program description - Joystick setting.
        And I am not sure, after I read the manual can I use it for reverse the channels?
        -Another option that i see is the Wing mixers;
        I will test today, if any other idea you have, you could write.
        Thanks, have a good day.
        • Under "servo adjustment"   - change the arrow direction to invert.  :)
          • Hi,
            This is only if the channel is reverse. :)
            Maybe there is some misunderstanding:
            - when it has to be pitch it act like roll. This was the problem.
            And yesterday I made it, it is easy to change them from "Advance list parameters". You can assign the channels manually(I forgot exactly which parameters I changed), but it's very easy, there is description in the right for this.
            To reverse one channel you can set again manually at:
            chNUMBER_REV        -1
            My new settings for PID are:
            "P" for  roll and pitch are 0,30,  it's react very fast.
            "D" and "I" are 0.0000
            So now it works perfect.
            But now I have another problem:
            - at my transmitter, I am almost at the middle of the sticks and the copter react like I am at the end.
            So from Pixhawk is there a option to make it work with all way of the sticks?
            • Maybe is normal in stabilize mode to be so aggressive.
  • sorry : "failsafe"
    When the receiver loses connection.
    • that's easy if you use with PWM , and even easier with PPM connection - easily set up in mission planner or APM planner.
      I suggest you check out documentation on ardupilot.com
      • Thank you,
        All is good now, but I have problems with config of PID..maybe.
        new discussion
  • That description seems to use 3 switches, to get 6 modes. - it also seems to use 3 of your precious 12channels. a mess. :)
    My way, is to mix CTRL9 + SW8 directly in MX-20 , then send output in one channel.
    If you understand my notes /(I expect you to do) :) - and do it right, there's no adjusting or tuning - all 6 modes will be hit perfectly within PWM limits.
    Input5 Ctrl9 (Ct9)
    Input10 Sw8 (8)
    Servo adjustment
    S5 travel 65% 59%
    S10 travel 70% 85%
    Free Mixers
    fr10->to5
    symmetric +20% +20%
    ch5= main mixed output
    Enjoy :)
