long range video is expensive ! you can use regular 5.8 TxRx and DVR. Your RC radio controls the drone and data radio you need to add cheep data radio if your not using expensive long range video that has data radio built in as well .
I checked out that parts of you offered, it will be too expensive i think. :( i guess if i get sd live video feed not hd will be better for price. what do you think? also the range of control the uav will increase, yes?
Thank you OG, checking out the links. i will build it my self and i need help ofcourse.
OG said:
you might want to look at popular airplane platforms , you need to add Camera, RC radio, ESC & brushless Motor . will you build it your self or do you need help?
Thank you for attention first of all. I want to make like an airplane, not a copter or not a volt. For mapping with live feed video transmission for lange range at least between 5-10 kms.
SURE ! PM me
Anna said:
TS832 transiver and receiver is not so expensive with 5km range. Ofcourse i have not an experiense with this, i need your help if for you it is ok?
regards.
Plane:
http://brushlessgimbal.ca/FPV/Ranger-EX-Long-Range-Fpv-Suas-Platfor...
http://brushlessgimbal.ca/FPV/Skywalker-X8-Flying-Wing-FPV-Expert
FC:
http://brushlessgimbal.ca/Auto-Pilot-Flight-Controller/Pix-Hawk-V5-...
http://brushlessgimbal.ca/Auto-Pilot-Flight-Controller/RTK-GNSS-Com...
air speed sensor :
http://brushlessgimbal.ca/Auto-Pilot-Flight-Controller/PT60-Airspee...
long range radio :
http://brushlessgimbal.ca/Auto-Pilot-Flight-Controller/Two-Way-Data...
what are thinking of building a air plane, volt, or copter ?
