Hello Everyone,
I am quite new with ArduPilot. I was curious whether it is possible to program it? All I need is ArduPilot listening for some data communication at some port. Is it possible to generate serial communication between ArduPilot and Raspberry Pi? If it is possible, which port should I use? I think some of the ports are already used for Telemetry and GPS. Moreover, how do I program ArduPilot? Do I need to change its firmware code? Which program do I use to program it?
It would be great if you could help with example.
Thanks in advance.
Aakash
I am looking forward to do something similar to you.
What i have been able to till now is
1.Install Ser2net package on raspberry pi by referring to http://diydrones.com/forum/topics/need-help-for-serial-comunication...
but there is no information after this ? It would great help if someone can add next steps to access data from APM <--->Raspberry pi or from Raspberry pi<--->APM.
Chethan
If you want to send it commands, look at the Mavlink protocol.
Probably good to start with the dev wiki. best of luck.
