How to set up A9 for camera triggering
Hi please I need some help, I have connected my camere trigger between S and - pins on A9. The problem is that test relay on test screen works fine, but, on mission planner doesnt. And on flight screen right click on mouse .---> trigger camera now, and the relay function turn on and remaind so.... doesnt back to off .
How is the correct way to use camera trigger in APM2,5 ?
thanks for your help
  • Did you get this figured out? Im not having any movements on mine.
  • Are you using 2.72? There was a bug in previous versions which prevent APM 2.5 to switch off the relay.
  • What is your CAM_DURATION parameter set to? By default it is 10, which means it will keep the relay HIGH for 10 seconds.
