  • Hey Guys could some one clarify this as their setup looks the same as the set up in this instruction for the X config.
    http://code.google.com/p/arducopter/wiki/AC2_Radio  (page shows different orientations for APM based on + or X config)
    On the same instruction page it shows the setup you describe (APM forward over leg 1) but only for the + config.
  • No - Your board orientation should be over the front left arm not in between them - So it needs to rotate 45 deg to the left -
    Mike
