MinimOSD Extra - Pixhawk - 3.1.5 - RSSI
Ok my OSD will come up and I thought I would add the RSSI data from the FrSky X8R however after I set the voltage read to 3.3 v and connect the RSSI port to the SBUS port 103 it says 48% maybe 47% but does not seem to move.. I can change the other setting for the read pin and it will got down to 38% but seems I am doing something wrong...
After this change I noticed the the minim OSD will stop updating after take off... (this was fixed by updateding the minim-osd extra code to a newer update)
any guidance will be much appreciated.. maybe some double checking of the RSSI out to the sbus port and the proper configuration as I cannot seem to find the answers definitively
it may be coincidence but anyone else that can lend some advice it would be much appreciated..
            • Did it work better with the filter?
    • Can you explane this mod/filter?
  • Does anyone know the proper setup for this?
  • Did you get this working?
    I have a pixhawk, X8R and MinimOSD as well and would like to see a setup help for this as well.
    • Not yet, hoping someone gives some insight on the configuration
