Mission Planner and 2.0.36
Doing well with .35 so I moved on to .36 this evening.  I updated the Mission Planner software first.  Just to let you know that the Mission Planner had a hard time detecting my APM version, took a few times.  Then when loading .36 it failed during APM Verify.  A box came up stating upload was completed successfully but verify failed.  The bad thing was that I could not clear that box, it would return continually.  This was always an easy process until tonight.  Just FYI.
Mat
    I'm finding that 2.0.33 seems the best for my Hexa right now.  Updated to 2.0.36, then down to 2.0.34, the down again to 2.0.33.
    I think my APM 2560 has arrived an is waiting for me at my office.
  • Same issue with the APM Planner 1.36 and the Failed to Verify Issue. I used Arduino to upload and used APM 1.36 to configure. Flew the quad and all seemed normal.
    I just tried to check the logs, but was not able to see any. If you disconnect the battery, do you lose your logs?
  • Same problem here. I first updated Mission Planner and it now shows version 1.0.36 in it's start up screen. I started the AC2 firmware update and get to the very end and receive the message -update successful verify failed, and was not able to clear that dialog pop up, had to restart my computer. I repeated this entire process three times with the same results each time. I went ahead and did the initial setup and then a very short hover only test flight with no problems however.
    Update your Mission Planner to the latest version. 1.0.36
sam liked Jimmy Oliver's profile
Aug 25
Mike Whitney liked Mike Whitney's profile
Jul 19
Abdulatif Tlaib liked Ryan's profile
Jun 24
