I would be very grateful if someone could help me with this. Since about 3 weeks ago the Mission Planner will not load any tiles below a viewing altitude of about 100km, this is not very useful for mission planning.
Before then I had excellent images of our property but now I can't zoom in on anything within a ~50km radius of where I live.
- Google Earth loads high resolution maps of the area perfectly, even after deleting all caches
- Mission Planner has been installed on 3 computers including a fresh install yesterday but none work
- I get the error message on each tile
"Exception: the remote server returned an error: (404) not found. We are sorry, but we don't have imagery at this zoom level for this region."
- My location is Latitude -41.809567° Longitude 173.863912°
- Mission Planner loads other areas at a high resolution without any errors
If someone could maybe try these co ordinates in their Mission Planner that would be great thanks!
Tom
have not tried re installing the msi versionI. I'll stick with the zipped version for now.
I had the exact same problem.
As I was troubleshooting the issue I unplugged the USB hard drive from my laptop. Everything started to work.
Looking back, everything was working for weeks and then I plugged the USB hard drive into the laptop. It was from that point on I could not scale up or down (load images) by rolling the mouse wheel (a USB mouse).
Did you ever get maps to working It worked fine for me a month ago now it shows nothing or I cant zoom in any fix for this
it updated a wile ago now it works fine
I've got the same problem here today with 1.2.88. This happened without any obvious change on my computer (maybe with few windows 7 updates). 1.2.88 worked well before (and I even had preloaded the map) . After my friends told me he can't load the map, I renamed the preload folder and found the map can't load anymore. (The preload file still do work)
I've tried update the mission planner to newest version or beta still with same issue.
The symptom are shown below
1. Unable to load under certain zoom
2.Shiwing low level tiles zoom out
3. Partially work and else not
I'm having the same issue. First I had to download the zip because my regular copy stopped opening. An error came up right after booting but I don't remember what it said. First time that ever happened but I figured something must have gotten corrupted. So I downloaded the zip and it's not loading the maps for my local area. I can zoom way out and most far out zoom levels work with the exception of the farthest out view and the next to it. Zooming in I start to lose detail as I get to the highest 3-4 levels. Now I'm using the prefetch in the flight plan screen. It's downloading for that zoom level but something seems broken.
Also I redownloaded the zip and tried again but same problem.
Could it be a wifi issue and your not connected to the internet for some reason so it can't refresh the data?
Didn't work for me, in fact it made it worse. I couldn't download map tiles for anywhere in the world at any zoom level
Well I uninstalled MP, downloaded the zip version, extracted it to my PC and executed the MissionPlannner10.exe and it seems to work fine now. I have not tried re installing the msi versionI. I'll stick with the zipped version for now.
Any news on this? I am having the same problem since the last MP update.... MP is almost useless to me now.
Bruce
