  • I know that this question is a little bit out of the thread but do anyone know if there is a possibility to combine gps, sonar and optical flow in apm mini 3.1. Nice work by the way!
    Awesome!
    Do we have transfer from GPS to flow and back yet? :P
  • Thanks to Goro, Pual, Randy.
    I got Optical Flow works well. Here is the video clip fling with OF
    P.S : The GPS is for only mag sensor not GPS
  • Hi Paul,
    FW : AC3.3.3 RC2
    Pixhawk
    I'm still struggling with OF.
    I found that Lidar is indicating correct alt  and OF log is shown in MP's log analyzer ( but not match each other OF.flow, OF.body IMU.Gyro like wiki )
    Even with AC3.3.3 RC2 + EKF_GPS_TYPE=3, my copter can't be armed with the message GPS 3D Lock error.
    I followed your instruction about NSH and it shows no error
    3702173023?profile=original
    It'll be very appreciated if you correct me ^^;
    P.S : Log file is attached here ( https://drive.google.com/file/d/0B713ZYObFHOTM0dncmFFdzJaOVE/view?u... )
    3702172974?profile=original
    3702172587?profile=original
    2016-01-30 18-16-21 3.bin.log
    • Hi Kyomo,
      Your log shows GPS_HDOP_GOOD parameter is not set correctly. You need to set it to 9999.
      Alternately, you can disable the pre-arm GPS check by setting ARMING_CHECK to -9.
      • Thanks Goro,
        I found it had not only one problem ^^;
        1st, I've set parameters to what you mentioned but still not armed.
        2nd, my OF has power issue so I had to power it up via USB first.
        ( I have two OF but both have same issue -.- )
        3rd, the worst one...my I2C splitter had faulty even though OF looked normal blinking LED signal.
        By replacing it with other splitter, it worked.
        With the above 3 treatment it was armed in Loiter mode without GPS.
        Thanks again Goro and Paul you guys' sharing information.
        • Hi!
          Did you manage to arm without GPS-module on the board? For example, can you totally disconnect the GPS-module and arm the copter with px4flow+lidar or you still need the 3dfix in the home position?
          • Yes, what I did
            GPS=disconnected
            GPS.Mag=connected
            FlightMode=Loiter
            and it was perfectly armed.
            • Thanks a lot!
              You say that you are using AC3.3.3 RC2. Have you compiled it from the sources or just downloaded through the Mission Planner (as beta version firmware)?
