Performing HIL Simulation with Custom Firmware
I am interested in doing hardware-in-the-loop simulation with my ArduPilot Mega 2.5.  We are developing a new controller architecture and I have implemented it in some firmware changes I've made.
When I look for information about HIL simulation, I mostly see people download a version of the firmware meant to do the simulation.  My question is, is creating an HIL version as simple as changing these parameters:
#define HIL_MODE                          HIL_MODE_DISABLED    (to HIL_MODE_SENSORS)
#define HIL_PORT 0 (to 3 for USB, or still 0?)
#define HIL_PROTOCOL HIL_PROTOCOL_MAVLINK
Could I just modify my custom firmware to include these changes, and load it as a hex the way I've been loading any custom firmware?
Also, do I have to use FlightGear (not Xplane) if I want the plane to know the raw sensor values? Or is that just a protocol issue?
Cheers!
Jon
University of Kentucky
  • hello, i want to ask to you, now i activate hil mode from source code and build that, but in parameter is still 0 for hil mode
    Menno Hochstenbach said:
    For ArduPlane is assume? ->
    Uncomment or add these lines to APM_Config.h file:
    #define HIL_MODE              HIL_MODE_SENSORS
    #define HIL_PORT                0
    Then just upload this custom code with ArduPilot Arduino IDE to your ArduPilot and it should work..
    Hi, I am interested in doing hardware-in-the-loop simulation with my ArduPilot Mega 2.5.  We are developing a new controller architecture and I have…
  • Hi Jon,
           Did you get solution for this? I am looking for a solution to similar problem. I need to use my modified code to work with HIL. Please help if you have a solution.
    • Sorry to drop the thread.
      I did manage to get HIL simulation working with my customized version of the 2.74b firmware and Flightgear.  In my APM_Config.h file I put
      #define HIL_PORT 0
      #define GPS_PROTOCOL GPS_PROTOCOL_HIL
      It worked very well with the exception of the airspeed.  Although the airspeed appeared in Mission Planner, the hardware did not appear to be receiving it. I managed to simulate AUTO mode by forcing the plane to use constant throttle (change min and max to same value).
  • Are you using ArduCopter or ArduPlane? For ArduPlane it should work, check: https://www.youtube.com/watch?v=tKr2C_Lrq_4.
    Menno
    • Hi Menno,
                 This video describes HIL with built in code. I am looking for solution with my modified code. Please help if you have solution.
      • For ArduPlane is assume? ->
        #define HIL_PORT                0
  • Hi,
    Have you already found a solution to do HIL with custom firmware because I want to do it to :)
    Menno
