For anyone still have trouble connecting via Xbee, please ensure that you're powering APM with an ESC/Lipo, not just USB. USB power is not enough for both APM and an Xbee. (You can sometimes tell that you're browning out because you just get the red C LED blinking dimly and slowly.)
I have tired with the trunk updates, different baund rates, I've even tried mixing it up a lil with different defines and baund rates. The most it will do is connect but no data. USB connects to everything well.
yea i guess im ok with CLI with USB only, it was like that with the NG code too,
Pid seems to be working and that is what is most important for me right now. the charts are laggy, but im sure in time it will be fixed..
happy flying
I just did an svn update of the 2.0.2 code and also the MP.
Loaded the 2.0.2 code with arduino.
Did setup with MP and noticed there is a line "xbee" added when you get the choice betweeb setup en sensor.
After setup I connected with USB to the sensor pages and everything looked fine.
Then I switched to Xbee (900) at 57600 and it works!!!!
I can go into sensors, PID settings, HK GCS, ...
One thing I noticed is that the graph in the GCS MAVLINK doesn't get any info.
Thx guys, keep up the nice work
Ok now lets get this thing in the air!!!!
i'm having similar issues as well, my quad worked with the pirate code so i know hardware is good.
i could get the sensor data but when i try the terminal i get giberish, and the pid tuning i get the above mentioned error.
when i use the mission planner to load the code where is that code stored so that i can go in and try modifying it?
