Pixhawk almost crashed during Autotune
Dears,
the work on my self-designed 3D printed hexacopter has been finished:) Some pics attached.
It can fly pretty well in all modes but I wanted to tune it with the Autotune functionality.
After the drone took off I switched to Althold and turned on the Autotune (Ch7). The drone tuned the PIDs for Roll for about 4 minutes and than... tried to fly away. I managed to put it to the ground by reducing throttle and disarming - it worked, uff.
After re-arming and checking the throttle on the ground I watched a strange behaviour - the drone tried to put the throttle to full when I only touched the throttle stick on the transmitter.
Now I am wondering what happened in the air and what is wrong with the configuration causing this strange throttle behaviour. I do not want to fly the drone until that's not clear for me and the issue solved.
Can someone with more experience maye help me on this?
I attached the log file from the fatal flight. Many thanks for any hint and suggestion.
BTW. I checked the PIDs and they stayed unchanged means autotune did not write any new values.
2017-06-11 20-00-09.bin
  • it did not try to flyaway. That's a DJI & other controller  feature :)
    if you plot the speed, you can see throttle demand on motor 3 max out (front left), and it's neighbour, #2 is also maxed out for a while. and yet the RPAS pitches down, and left.
    Something failed, and you had not enough lift there.
    you started out at 11.6 volts, so I guess you are using 3S , at the time of trouble you had only 3.55v/cell,  at lowest point only 3.39v/cell  - so a low voltage protection in ESC , or simply empty battery is not entirely ruled out.
