Pixhawk analog servo support?
Currently I'm looking at PixHawk to autopilot a Techpod drone. I can't seem to find whether the pixhawk supports analog servos, which run on 50Hz. I'm asking this because a lot of FBL systems for helicopters have no analog servo support.
Does anybody know? I've downloaded the software but I can't really do anything with it (change servo frequency) unless the pixhawk is connected.
Thanks!
    The APM:Plane firmware runs all servos at 50Hz. It should work with all servos.
    Cheers, Tridge
    • Hi Andrew,
      I have noticed that the servo movement is very "steppy" (for lack of a better word) Why is this?
      My Camera gimbal servo is not running smooth but it looks like it is moving in small steps to get to its endpoints. I am using digital servos for the gimbal.
      Thanks Andreas
      • Digital servos are kind of "steppy". I use analog servos on my gimbal for this reason.
  • The parameter    RC_SPEED   allows a range of 50Hz   to  490Hz  update rates.
    You may access this parameter from the Full-Parameter-List  section of the Config/Tuning tab in Mission Planner.
    • That’s the problem – the Airplane firmware does not have that parameter.
      For multirotors that RC_SPEED parameter is only for ESC control and is not used on the servo channels.
  • Works perfect with HXT 900 servos so it must be 50 Hz.
    If someone is a good code reader It would be nice if they could figure that out and post the answer.
    It would be a nice enhancement to be able to adjust servo frequency. Multi rotor firmware has that logic so they could just copy over the code.
  • I would like to know the answer to this as well.
    • Meanwhile I have the pixhawk, and without changing the servo frequency (I wasn't able to find the menu) it didn't fry my $3 HK analog servos. So you can :)
