Pixhawk ArduPlane 3.7.1 RTL Altitude Issue
Hi All
not sure why but every time I switch from Auto to RTL the plane pitch down almost crushing before starting to climb to ALT_HOLD_RTL.
see attached picture, and log is at:
https://drive.google.com/file/d/0B4WjC265IPbLSWFpOHF1VVpWelk/view?usp=sharing
Please help debug.3691340963?profile=original
  • -elevator trim (RC2_TRIM) is not what you radio does.
    -airspeed is wrong, seems to be much higher than GS regardless of direction you fly in.  , correct or learn ARSPD_RATIO
  • can you be more specific? what do you see the is poorly setup?
    Andre K. said:
    your elevator _TRIM setting does not match your TX config, airspeed is far from correct, , none of those causes it, but you need to check everything as even such basic things are poorly set up.
  • your elevator _TRIM setting does not match your TX config, airspeed is far from correct, , none of those causes it, but you need to check everything as even such basic things are poorly set up.
