Pixhawk - Back-Up Power via USB port
I'm building a hybrid UAV with a Pixhawk flight controller for use in a competition. As far as i've understood a requirement of the competition is to have a back-up power supply for the flight controller ONLY (does not power any actuators). I think this is to maintain contact with the UAV until it crashes if main power is lost.
My question is:
Can i use a small 2S (~7V) battery regulated to 5V with a BEC into the USB port while powering the pixhawk normally via main Power Port and then the Motors/Actuators via ESC/BEC's on the Servo Rail?
Second question, is there any difference between the vertical facing "USB" port and the side microUSB port on the Pixhawk?
My understanding is the pixhawk will have to loose power to both Main Power and Servo Rail before it uses the USB power, so i feel like it should be fine. However, in the past i have blown a 3.3V regulator on a Pixhawk and i suspect i did it by powering the main port and USB port at the same time while calibrating things. Not sure on this.
Thanks!
  • to answer your question: yes, the USB DF-13 and micro-USB connector are directly connected.  - so you can get power redundancy from any of those.
    The redundancy is for Pixhawk, recieiver, telemetry radio...  the USB power will not be used to power servo rail.   Power redundancy is to ensure safe/reliable power for electronics, - and allow more noisy power from multiple BEC's on the servo rail.   - not to protect from depleted batteries.
    The scorpion thingy (an expesive 5v BEC with 2s 500mAh battery) is not something you need.  - unless you plan to drain the main battery hoping that 500mAh extra will save the day.
    • Thank You Andre :)
      Just what i needed to know.
  • Take a look at this- works really great is independent and light:
    http://www.scorpionsystem.com/catalog/accessories/backup_guard/S_Ba...
    Joe
Mike Whitney liked Mike Whitney's profile
Jul 19
DIY Robocars via Twitter
Jul 2
Jun 26
Abdulatif Tlaib liked Ryan's profile
Jun 24
RT @SmallpixelCar: First time at @wsraceways. After tuning @HokuyoUsa lidar signal and camera sensor on @NVIDIAEmbedded, my car was able to…
Jun 20
RT @breadcentric: The handy bit about racing with self-driving cars is that one can type while the car is racing. Report from #AWSDeepRacer…
Jun 18
RT @chr1sa: Our Bay Area @DIYRobocars meetup is now at 2,700 members. Next in-person events (in Oakland) are training day on July 17 and…
Jun 18
Videos from the ICRA autonomous racing workshop are now available: https://linklab-uva.github.io/icra-autonomous-racing/
Jun 10
RT @SmallpixelCar: Prepared race track for Warm Spring Raceways @wsraceways and looking forward to test my new car at RAMS RC @ramsaicar fa…
Jun 6
RT @f1tenth: Trying out some nasty blocking maneuvers 🏎️🤖 #f1tenth #autonomousracing https://t.co/nMTstsaogM
Jun 5
May 27
RT @araffin2: I will talk this Saturday from 18:00 to 19:00 Paris time for the @diyrobocars community about learning to race in hours using…
May 27
RT @a1k0n: Luckily the infeasible hairpin problem was easily reproducible in simulation and I could test the fix before bringing the car ba…
May 26
RT @a1k0n: Another problem was that I was over-constraining the car's allowed accelerations, so it didn't think it could turn as tight as i…
May 26
RT @a1k0n: Breaking the map up into two halves worked, but I had to be more careful about separating the inner track from outer. There's se…
May 26
RT @a1k0n: Here's a datalog for my fastest lap of the day. Lap timer is tiny window lower-left. https://t.co/myrlWWrKUY
May 26
