Pixhawk shoots straiht up
Hello folks,
I installed my new Pixhawk earlier today. I configured everything like i did on the APM before.
I took my octo for a first flight to test all configurations, vibrations and params. as i switched to AltHold mode it hoovered for half a second and then shot straight up with nearly full throttle. After switching back to Stabilze immediately i was able to control it again.
I started to look for a topic here in the forum but only found some similar problem descriptions. i also read that this could happen due the missing foam over the baro on the APMs. i never had an issue with my APM 2.6 on the octo.
Tried it a second time with the same problems and a crash at the last 2 feet while landing (my fault)
Vibrations are in acceptable range.
Can someone help me with that?
  • No I haven't tried others, just left at the 250 default. It's for aerial platform and I'm looking for a tame stable flying platform.
    -Jon
  • What value did you use in the setting?
  • Thank you
  • Benjamin, you reminded me of him:
    Te4YvTJ.pngThank you
  • What did you end up setting the PILOT_VELZ_MAX value at? I have the same problem in Alt Hold and Drift mode. It shoots up like a rocket. Loiter and Stabilize are fine.
    Jon
