PixRacer with Ardupilot
This is a discussion to focus the feedback and support of ardupilot on the PixRacer board from AUAV.co.
We believe that all teething problems encountered are now resolved and so we recommend people load Copter-3.3.4 which is available for all multicopters through the Mission Planner's (and other GCS's) Install Firmware screens.  Note that because regular Pixhawks are still on Copter-3.3.3 the install icon may show Copter-3.3.3 but rest assured, Copter-3.3.4 will be installed (you can check the version by looking at the very top of the Mission Planner).
3691274249?profile=original
      • I can certainly confirm the arming light is always solid/armed w/ APM and PX4, and it has been my suspicion that may be part of the issue w/ ESC calibration w/ APM..   Developers will have to fill us in w/ more info..
      • Oh man that would be great if Randy can fix it, I don't think I can get calibrated without it working since my Rx is PPM only.
        • Do you have an ESC programmer? You can set the end points in there..  Since my RX is in PPM mode, that's what I ended up doing..
          They did calibrate w/ PWM, but the end points weren't right when it was connected via PPM... So I just hooked up an ESC programmer and set them numerically in the program.
          • No, I don't have one, ill keep hopes that the devs will be able to fix the All At Once for the racer soon, in the mean time ill set everything else up.
    • Another thing I noticed is the light is supposed to blink and when you press the button it should go solid.
      But on the Pixracer the light never blinks, you can see it in my video.
    • Pretty easy. Just watch this. It's how I learned. http://youtu.be/B-0YlqRn7UQ
      • Oh, my receiver is a PPM only, just one bind plug and one PPM plug, there is no throttle plug.
    • Thanks David, well that sounds like an issue with pixracer then?
      It would be nice to get All At Once working again.
      Sorry for my ignorance but I don't know how to to manually calibrate them, I have only done this via all at once in the past.  Can you send a link on manual calibration.
    • I haven't calibrated any other FC's since 3.3.0 was released, but back then, Pixhawk, HK clone, and AUAV-X2 all calibrated successfully all at once.  Pixracer on 3.3.3/3.3.4, no luck.
  • I can not get the all at once calibration to work,
    Unplug battery
    Throttle up
    Plug in battery
    Unplug batttery
    Plug in battery
    Wait for tone
    Press safety button
    Waiting for my ESC to play music thru the motors and they never do, tried to throttle down and still my ESC wont play their tones that they are being calibrated.
