During tesing of motor-off recovery at safe altitude (60meters), the quad fell stright down, - propellers were spinning backwards, and motors stalled, not being able to turn in right direction.
At much too low altitude, the quad rolled, making 2 of the motors able to spin up, but it was too late then.
-motors should be kept on at all time when the APM is armed, stopping motors is asking for dangerous situations..
I created a issue here: https://github.com/diydrones/ardupilot/issues/431
Feel free to support it.
I think a feature which would be handy and along the same vein as this would be a "rapid descend" where the APM will bring it down as quickly as possible but without stalling the motors (tell-tale sign without feedback is uncommanded pitching or rolling)
I often descend for the fun of it with the motors just about stalling. I bring it down as quick as possible and as and when they stall I give it a bit of throttle. From an APM PoV it would be tough because of the instability caused by falling through your own prop wash.
The option used to be there to either spin motors when armed or not. Option seems to have been removed somewhere along the way.
Making the motors always spin when armed creates a whole lot of new problems. You can't shut them down when things go horribly wrong, to reduce damage (both to copter and to people/property). You have arming and disarming delay which may confuse people(hey why don't my motors start, oh now that I put my finger in they start), etc.
Furthermore you have the variable pwm value of "stationary spin' for different copters. An overpowered copter may take off when spinning at a stationary pwm, while a normal one does not. For some esc's the stationary pwm might be insufficient to make the motors spin. For esc's without external oscillator the stationary rpm will vary with temperature, etc etc
The issue has been brought up before on the developpers list. But my opinion is that a pilot still needs some common sense and that a machine will never be able to replace that.
To recap and make certain we are not misinterpreting your test:
Based on this experiment, you are petitioning the developers to implement a flight mode that completely compensates for any pilot action of shutting down the motors in flight? In short, you are asking for a 'smart throttle' function.
Interesting concept.
Nylon or other plastic screws may not be a bad idea if they do not get too hot and soften or deform and then twist. In the case where the arm is aluminum, some heat sink action of the motor base and the arm may delay this possibility.
-=Doug
I like the idea of once the APM knows you are in the air it should prevent a full zero throttle in stabilize mode. If you really want to shut them off then go to ACRO. Full off shouldn't be allowed in stabilize like it's not in other modes like alt hold. But it should be able to descend faster than a full down in alt hold. Just keep them spinning at the minimum speed that prevents them from stopping.
If you stop the motors mid-flight you're rolling the dice as to whether they will start up again.
As you say, they reverse in freefall and the ESCs can't get back in sync to move them the right way again, they're not designed to be able to handle that case.
I am confused. Did you intentionally stop your motors in flight?
Was this to test an added safety circuit or some other failsafe/rescue mechanism?
Or are you stating that while flying, two of your motors stopped?
It is unclear if you are reporting an induced result or a system failure?
Please clarify. If a system failure, post your *.tlog file from the APM so that we may attempt to augur out the cause...perhaps.
It is sad to see damage but let us hope you can learn what went wrong.
-=Doug
