Hi
Two of my customers have trouble setting up the Pixhawk - I myself have a Pixhawk, but don't use a Futaba receiver, thereby I can't replicate the problem (I would like to find out if the problem is connected to the receiver they use, or something else).
Both use a Futaba R7008SB receiver.
Both managed to upload the Firmware to their Pixhawks - but they are not able to do the radio calibration (the Pixhawk doesn't "see" the receivers, the bars in the calibration are all grey).
They have nothing else connected to the Pixhawk, except receiver (connected to the right port / RC), buzzer, safety switch and USB cable.
The Pixhawk signals via the big LED "pre-arm check failed" (which makes sense ;)
They power the Pixhawk via USB and at the same time with a LiPo (via the Power Module).
The receiver is "found" by the remote, the LEDs are on, the setting of receiver and remote (regarding the use of the SBUS) seems to be right. They use the right port of the receiver to connect to the Pixhawk.
I am happy about any suggestions ...
Thanks a lot in advance
Felix
Dear Martin,
At last I got a PPM encoder and it started working now. But only on one condition, after each power on I have to press the Pixhawk reset switch for some time!!!! Then its start working. Do you suspect any firmware issues????
Thank you
Madhuraj
Great to hear from you and im glad to gear things are improving! When you refer to the reset switch are you talking about the fmu reset switch located next to the USB port on the side of the pixhawk or the safety switch?
I am using the 14sg and 7008sb on a 3Dr Aero and it works fine. I cant get the 7008sb to even work on arducopter latest version even with a PPM encoder? Any thoughts as to why?
Hello Aaron, which modus did you select for the R700SB? You can select different mods by holding the small swith when powering the RX. The red LED will flash:
1x when in mode 1
2x when in mode 2
etc. I believe there are 4 mods. Mode 1 is the right one.
I tried everything I could find on the net. I followed the directions to set the mode but it always stayed in mode 1/A. Had it plugged into ch8/ sbus and also tried sbus2. nothing worked. I ended up buying a r2008sb and it works great. maybe I will use it on my next copter or plane.
"Pixhawk is a PPM-input autopilot, which means that it gets RC input from a single cable to the receiver, either via the PPM port, the Futaba S.BUS port, or the special satellite receiver port for Spektrum gear"
"Most modern RC receivers (and all those sold by 3D Robotics) allow for PPM output, but some, such as non-S.BUS Futaba receivers, do not."
So why I need a PPM encoder when on 3DR site I read Pixhawk support S.BUS?
I cant use my Pixhawk (I orderd 1 years ago) and still wait for S.BUS supported firmware version.
I tried RC versions but I have a near flyaway so wait stable.
I paid 530$ for Pixhawk with shipping, fees and customs. And now I can sell about 150$.
Pixhawk 3.1.5 equal with APM 2.6.
So Pixhawk software not released yet and I think do not release 3.2 this year(too much bugs).
Pixhawk hardware good but need 1-2 years to software use it.
Yep, I agree, really not so bad to use the encoder.
I was able to get the SBus working with one of the firmwares, haven't had time to look at this project again, but I bought the encoder and now I can use it with any firmware, no need to worry about the SBus
It might be irritating not getting something to work the way you (Xian06) had hoped, but no reason to throw away a good controller just because one small problem. I bet you are going to have another 1000 problems before you get to fly well or fly at all. If you are going to want to throw the controller at the wall or sell it everytime a problem comes up then you aren't going to get very far. I bet you every controller on the market has some kind of issue. You could always buy a DJ and have a fly-away on SBus :)
I went through exactly the same thing when this happened to me so I know how you feel. I started reading up on the other controllers and I decided to buy the encoder. The rest are just not as good as this controller, from my research. Not to say that I did great research so you will need to go through that yourself.
