I am working on a 1.2m Quad with Pixhawk. First I had problems with the green Turnigy Multistar ESC, but after flashing SimonK they work very smooth and sensitive.
Now the problem: When increasing yaw over 50% the two slower rotating motors start to oscillate in their RPM at about 10Hz. This happened in flight (with a successive crash) but also when the copter is tied down stationary.
Here is a screenshot from the logs, it looks like the oscillations are coming from the flightcontroller RCOU.Chan1-4 (note: the log frequency is much lower than the oscillation frequency):
- Videos:
- https://www.youtube.com/watch?v=D9MPRoRQCVw (here you can see in the last seconds what happens when yaw > 50%)
- https://www.youtube.com/watch?v=ZCc6QrucXbk (here you can hear the oscillation frequency, I yaw for 1s intervals)
- https://www.youtube.com/watch?v=IPVtwNXuRLU (here with more throttle, louder)
- https://www.youtube.com/watch?v=VNytjc2gNdI (hovering with little inputs on all axis is smooth)
- Specs
- H Quad, 1200mm, Pixhawk
- Motors: Turnigy Multistar 6135 330kV http://www.hobbyking.com/hobbyking/store/__45362__6135_330KV_Turnigy_Multistar_Brushless_Multi_Rotor_Motors_CW_CCW_2_pcs_.html
- ESC: Turnigy Multistar 45 Amp 2-6S (OPTO) with SimonK http://www.hobbyking.com/hobbyking/store/__27777__Turnigy_Multistar_45_Amp_Multi_rotor_Brushless_ESC_2_6S_OPTO_.html
- Props: 18x4 Carbon Fiber Propellers for DJI S800 http://www.hobbyking.com/hobbyking/store/__42855__18x4_Carbon_Fiber_Propellers_for_DJI_S800_L_H_and_R_H_Rotation_1_pair_.html
- Batteries: ZIPPY Compact 5000mAh 6S 25C http://www.hobbyking.com/hobbyking/store/__21373__ZIPPY_Compact_5000mAh_6S_25C_Lipo_Pack.html
I found the root cause: The Multistar ESCs are loosing sync with the Multistar motors (hello HobbyKing). No stuttering with Turnigy Plush. But those are slow at regulating RPM, so I am looking for fast ESCs that work with those motors.
Hi Erik,
Looking at your videos I really feel you have a frame/hardware issue. First you have an H frame configuration combined with a really big size. H frames are known to have Yaw problems (because of the frame flexing) and you increase even more the flexing issue with a bigger size. Your frame does not look very rigid on the video, you can see it flexing like marshmallow.
Second, the sound of your motors do not sound very good, it is like they are rubbing on something!?
If I were you I would modify the frame to be in a X rigid form factor with the same motors,escs,props and see if then your issue remains or not. That test would define if it is a software or hardware root cause.
The bad sound of the motors is _because_ of the oscillations.
Regardless: I don't get them with props removed. So it has to be some resonance between the props and the Pixhawk coupled over flexing frame. Will have to stiffen the frame.
Btw MOT_SPIN_ARMED doesn't work anymore with the 3.2 rc10 firmware. And with 3.1 changes to MOT_SPIN_ARMED and THR_MIN_SPEED are only active after a reboot.
@ Xian06 What issue are you referring to? I am not aware of an issue that causes this that is fixed in rc10.
Hi Erik,
To answer your question about why this isn't an bug report for github. Basically this has not been identified as a problem with the code. Instead it is most likely a problem with your tuning or hardware choices and setup. Until we can establish there is a problem to fix with the code we keep these issues on the forum. Here people will work with you to work out the problem and help you fix it. A but report is you helping us fix a problem with the code.
Could you post a log so I can look at your issue myself. I have a large hex with a similar setup but running on 4s. I didn't have any problems with the Multistar 45 A Opto esc's and so far the copter has performed beautifully.
Maybe this change?
ArduCopter 3.2-rc8 11-Sep-2014
Changes from 3.2-rc7
1) EKF reduced ripple to resolve copter motor pulsing
Hi Erik,
Maybe but I don't think so. What version are you using, do you have EKF on?
Again, your log helps here.
Would using an older firmware version fix the problem until rc10 is out?
