Raspberry Pi and Mission Planner?
Hello everyone,
I was just wondering if anyone has tried doing anything with the Raspberry Pi boards and Mission Planner? http://www.raspberrypi.org
If it is possible to get the software working on the board with a usb video capture stick or something you would be able to have full telemetry and video in a footprint that could be stuck to the back of your radio. The power requirement os also quite low, and would be a lot more convenient than balancing a laptop somewhere.
I will have a more in depth look into it next week :) Just thought I'd see if anyone had looked into this setup at all.3690970077?profile=originalhttp://www.raspberrypi.org
  • Yep, I just compiled it on my Pi using the Linux instructions.  After 5 hours, I left it and went to bed, it was done compiling in the morning. 8-)  Starts up fine, no errors.
    As for the display, I use an hdmi-vga dongle.
    Rick
  • As far as I'm aware (I might be wrong) the raspberryPi hasn't got composite-in, only composite out. Composite in would be good for integrating fpv video in Mission Planner.
    Also, there is a more powerful board called the hummingboard (http://gizmodo.com/raspberry-pi-has-a-tiny-45-pc-competitor-1599677115) This might run Mission Planner & FPV video together.
    h6ziaj3nangbenp3eeu3.jpg?width=400
    • Actually, there's an idea. Combine a Hummingboard (http://www.solid-run.com/products/hummingboard/), with a RC305 video receiver, a 7" touchscreen monitor....Load DroidPlanner onto it...Mount it to your Taranis...And you have both recorded FPV & touchscreen GCS. And A/B switch to change between the 2 screens. Nice idea huh? Who's good at getting me Kickstarter funded? :) :) :)
    I've been experimenting with a 4G LTE Dongle and Raspberry Pi as a telemetry system for pixhawk.  I've also thought of using it for video, but haven't had the time for those experiments yet.
  • I personally have not done it but it is detailed how to here:
    http://www.rcgroups.com/forums/showthread.php?t=2169852
  • What about running droid planner or andropilot on one of the more recent and powerful boards like beaglebone/cubieboard/pcduino/olinuxino/odroid, that are all capable of running linux/android and all come with 1ghz or more processor and 2gb of RAM?
    I think this would be a solution to run a full featured GCS in a very small package.
    I'm probably going to try the olinuxino A20 board with its 10'' display, will let you know...
  • I'm interested in this proyect, but I think we need do something similar to apm with 3 or 4 machines, using wine or similar, it's possible??
  • Any new development with this project?
    thank you.
  • sudo apt-get install phonon libqt4-dev \
    libphonon-dev libphonon4 phonon-backend-gstreamer \
    qtcreator libsdl1.2-dev libflite1 flite1-dev \
    build-essential libopenscenegraph-dev openscenegraph\
    flite flite-devel
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    E: Unable to locate package openscenegraphflite
    E: Unable to locate package flite-devel
    root@raspberrypi:/home/pi#
    I would try running this project on the Pi https://github.com/wiseman/mavelous
    wiseman/mavelous
    multi-platform ground station for drones that speak the MAVLink protocol - wiseman/mavelous
