Hi All,
I would like to introduce you to a new radio modem that we developed for very long range datalinks!
http://rfdesign.com.au/RFD900.php
Some of the key features of the RFD900 are as follows:
- Multi point and point to point link capability.
- Long range >40km depending on antennas and GCS setup.
- 2 x RP-SMA RF connectors, diversity switched.
- 1 Watt (+30dBm) transmit power.
- Transmit low pass filter.
- > 20dB Low noise amplifier.
- RX SAW filter.
- Passive front end band pass filter.
- Open source firmware / tools, field upgradeable, easy to configure.
- Small (30 x 57 x 13 mm), light weight (14.5g).
- Compatible with 3DR / Hope-RF radio modules.
- License free use in Australia, Canada, USA, NZ.
These modems are designed to support long range applications, while being easy to use and affordable.
These modems have been flying in various platforms and have demonstrated excellent performance in real applications.
RFD900 modems are now available at: http://store.rfdesign.com.au
Support within APM planner and the radio configurator from Michael Oborne is already available.
It works seamlessly with APM planner, all radio Mavlink parameters are available.
Update, December 2014: The RFD900+ with improved specifications is available now at:
http://store.rfdesign.com.au/rfd-900p-modem/
Seppo Saario
rfdesign.com.au
there's a super helpful post from Kent at RFDesign who gave details on what setting/s to change.... here: http://diydrones.com/forum/topics/rfd900-new-long-range-radio-modem...
We have purchased some 900x radios and I am looking for information on using the PPM passthrough mode.
Do I need to setup the Radio with AT commands or can it all be done inside of mission planner CIN and COUT check boxes...
i.e. setup Pins as Input / Output?
RTPP
put Val: 0
Pin:1 Output Val: 0
Pin:2 Output Val: 0
Pin:3 Output Val: 0
Pin:4 Output Val: 0
Pin:5 Output Val: 0
ATPP
Pin:0 Output Val: 0
Pin:1 Output Val: 0
Pin:2 Output Val: 0
Pin:3 Output Val: 0
Pin:4 Output Val: 0
Pin:5 Input Val: 1
ATPI=4
OK
ATPP
Pin:0 Output Val: 0
Pin:1 Output Val: 0
Pin:2 Output Val: 0
Pin:3 Output Val: 0
Pin:4 Input Val: 1
Pin:5 Input Val: 1
RTZ
From discussion it looks like GPI1_1R/CIN and GPI1_1R/COUT refer to pin 15 - is that correct?
15 P2.6 Either Digital I/O 5V
ATI5
S0:FORMAT=32
S1:SERIAL_SPEED=57
S2:AIR_SPEED=64
S3:NETID=14
S4:TXPOWER=11
S5:ECC=0
S6:MAVLINK=1
S7:OPPRESEND=1
S8:MIN_FREQ=915000
S9:MAX_FREQ=928000
S10:NUM_CHANNELS=20
S11:DUTY_CYCLE=100
S12:LBT_RSSI=0
S13:RTSCTS=0
S14:MAX_WINDOW=131
S15:ENCRYPTION_LEVEL=0
S16:GPI1_1R/CIN=1
S17:GPO1_1R/COUT=0
R0:TARGET_RSSI=255
R1:HYSTERESIS_RSSI=50
RTI5
S0:FORMAT=32
S1:SERIAL_SPEED=57
S2:AIR_SPEED=64
S3:NETID=14
S4:TXPOWER=11
S5:ECC=0
S6:MAVLINK=1
S7:OPPRESEND=0
S8:MIN_FREQ=915000
S9:MAX_FREQ=928000
S10:NUM_CHANNELS=20
S11:DUTY_CYCLE=100
S12:LBT_RSSI=0
S13:RTSCTS=0
S14NDOW=131
S16:GPI1_1R/CIN=0
S17:GPO1_1R/COUT=1
R0:TARGET_RSSI=255
ATPP
Pin:0 Output Val: 0
Pin:1 Output Val: 0
Pin:2 Output Val: 0
Pin:3 Output Val: 0
Pin:4 Input Val: 1
Pin:5 Input Val: 1
RTPP
Pin:0 Output Val: 0
Pin:1 Output Val: 0
Pin:2 Output Val: 0
Pin:3 Output Val: 0
Pin:4 Output Val: 0
Pin:5 Output Val: 0
Michael Nunan
ING Robotic Aviation
@benny arisusanto: Yes indeed! :-) RFD 900X solved
That is very encouraging . I'll measure the lag time on CPPM signal with a scope and will report the values.
Solve, mission planner can read 900x parameter.
Mission planner have to be update to Beta Update
@davidbuzz: Did you manage to get mission planner (with 900x on usb) talking to another 900x on an airframe?
davidbuzz said:
Don't need encryption at this stage,
I have air-frames grounded because of these incompatibilities between mission planner and 900x modems.
not good, :-(
Henri
Any user feedback on PPM through RFD900x ? A post is talking about expected latency, what kind are we expectinh here ?
Also do you plan a 868 Mhz modem for Europe ?
The RFD900x document is still in progress but most AT commands are common with rfd900+ (with exception to encryption and PPM configs)
The AT command set for rfd900+ can be found here:
http://rfdesign.com.au/documentation/sik-at-commands/
Kent
benny arisusanto said:
"Hello,
I have confirmed the issue and it is due to a slight change in the communications of the settings of the new modems. We have communicated the issue to the mission planner developer and expect that it will not be too difficult for him to fix. In the mean time the only supported method for updating or checking modem settings is to use the AT command set.
Moreton King
Type +++ at command and get reply OK
And then no answer from moreton what have to do.
rfd900x modems:
Did flash RFDSiK V2.53 rfd900x.bin using the RFD900x Flash Programmer: OK
Using Hyperterminal, I can use the AT commands and the modems are ok.
Unfortunately, mission planner isn't able to talk to these modems???
Don't know what to do next..
Any help welcome.
Thank you in advance.
Henri
