Setup of CHDK
I want to ask what is your setting of using CHDK? What setting did you use for taking a vertical static images? eg ISO, shutter speed... etc. I using quadcopter apm 2.5.I taken some picture, but it was blur.
  • Hi All,
    I have a powershot S110. While playing around with the ISO settings, It will only go up to 320. Is this 3200?? i.e. are they just leaving a zero off?
    Yes, what JP said. Shutter speed is critical.
    It also helps if you add vibration isolation for your camera.
    But at 1/2500, if you have the light for that quick of a shot, it doesn't matter as much.
  • Hello:
    Make sure your camera is in shutter priority mode "P" .. next try using a shutter speed of 1/1000th or higher. white balance should be set to a fixed setting 'day' or 'sunlight' and not 'auto'.. (depends on sky conditions)
    You can experiment with auto ISO or a fixed ISO to see what gives the most consistent images (brightness, contrast, colors)
    Good luck!
