Submit your ArduCopter configuration files here
This is a thread to submit ArduCopter configuration files (PID settings) for common airframes. Once they are reviewed, they will be placed in the manual here so that others may use them.
Along with your config file (saved from the Mission Planner), please list:
  • Frame type (quad, hexa, etc)
  • Manufacturer
  • Orientation (x or +, if relevant)
  • Motors
  • Props
  • APM 1 or 2
  • Any useful notes on performance or flying tips
  • Hey Jerry,
    Any idea where i can get a copy of your config file for the sk450? The place where the shared config files are meant to be is blank.
  • - Quad X
    - SK450
    - Sunnysky 2216 800kv
    - 10*45
    - AIO pro V1
    RTF ( 2200mha 3s) 1300g.you help yourself adjust parameters to fit in with the offline configuration.thanks
  • someone have F450 Configuration files?
    thanks!!
  • hello, all i have finish to assemble my new quad. but it is hard to stable fly. this is the picture. (i dont know is it my apm and battery is placed at the right area or not. this is the picture.
    can someone share with me the config for this quad?
    - Frame type = Quadcopter
    - frame = hobbyking sk450 with dead cat conversion
    - Orientation = X
    - Motor = Turnigy Aerodrive 2830 1000kv
    - ESC = Turnigy Multistar 30A Flashed to SimonK firmware
    Props = SlowFly 1045
    - FC = APM 2.5+
    - Battery = 3S Turnigy 25C 5000mAH
    thanks. :)
  • Hello,
    My config is:
    Frame Hexacopter with made by me !
    Motor:  NX_4006_530kv   http://www.hobbyking.com/hobbyking/store/__17923__NX_4006_530kv_Bru...
    Props: 12x4.5
    APM2 with latest firmware
    ESC: Turnigy plush 30A
    Lipo 5000mAh 4S
    Flight time: 12-14 min
    I can't use my lipo 3S because the power is decreased with the new firmware !!  :(
    I must use lipo 4S
    And you ? are you also forced to use 4S ??
  • Any config files for the standard jDrones frame?
  • Hobbyking Q450 APM2 in X config:
    Firmware 2.7.3
    Motors: NTM 28-30 750 kv
    Propellers: 10x6 (I will change to 10x45 SF)
    Battery: 3s 2650mah 25-50C / 4s 3000mah 20C
    Flight time 8 min with 3s battery :( and 12 min with 4s battery
    Is a non standard config ;)
    myparams_3s_4.param
  • Does anyone have some ballpark figures you suggest for my quad?
    I am using:
    • An xaircraft diy x450 frame
    • 25A ESCs
    • 1020KV motors
    • 10*4.5 props
    • 5000 mAh 3s 50C battery
    My frame weighs around 1.5kg i think, but I have yet to weigh it.
    Stabilise seems pretty good, but it wanders quite a lot in loiter.
    • QUAD
    • HobbyKing SK-450
    • Orientation is X
    • Motors are NTM 26-28a 1200kv
    • Props are 3D robotics 10.47" Props3692460398?profile=original
    sk450.param
  • Anyone config a dji 450 frame yet?
