Ticking noise from Motor, Motor ceased to rotate.
Hello All,
I have DYS 20Amp ESC, which when connected separately to DYS motor runs smoothly. I have performed Throttle Range Calibration, ESC is responding perfectly.
All ESC's were connected to Controller Board and gave perfect connection for Quad + configuration (along with Tx and Rx interfaced). When connecting 4s battery to the entire setup, One of the Motor is producing an Tic-Tic- Tic noise continuously. Arming operation is happening. The motor which is Ticking is not rotating, rest of the 3 motors are rotating when Throttle is increased.
Im not sure where the problem can be. Below are my config of my components used.
1. DYS 20Amp ESC
2. KK 2.1 FLight controller with LCD
3. DYS motors with 750KV, 350W
4. HK Transmitter & Rx, T6A V2 :
http://www.hobbyking.com/hobbyking/s...2_mode_2_.html
5. Nano Tech Lipo 4s, 4500maH, 35C. Also tried with Nano Tech Lipo 3S, 2200maH, 25C.
Please let me know if you need more details. Im not able to converge on this issue. Have you guys also ever faced such a problem ? What can be cause of this issue ? Thank you all ....
  • THANK YOU ALL. It was Connectivity Problem. The bad connectivity was present between battery and ESC..
  • It sounds like you may have a bad connection wire between the ESC and motor. I have had this before and re-soldered the wires on my ESC which fixed the problem.
    I hope this helps!
  • Also, try this ESC with another motor.
    And, compare behavior with another ESC with it's PWM disconnected.
  • Check that the ESC is getting PWM input, switch with another output to be sure us the ESC, not output.
