From your experience/ observations: What are the main specific reasons DIY mini-uavs crash & recommended equipment/procedure to address it(point form)? This discussion thread will serve as guideline for amateur uav designers, system integrators, operators, hobbyist etc. It contains the most likely failure modes to worry about on your uav &  the solutions. These statistics are brought to you, through the magic of crowd sourcing. This is a very important question since uavs are being integrated into the NAS by the FAA. Any thoughts(specific points, in point form preferred) ?
  • My issues...
    • Lack of redundancy - quads and hexes will generally fall from the sky if any prop / motor / ESC / cable fails. Octos are better.
    • Battery life issues - many crashes are the result of the low battery warning being too late (or not at all).
    • Compass issues for many flight modes - I've suffered a serious crash because of this. Little or no logic in flight controller to detect this and react.
    Based on my experience, the flight controllers need to improve to detect a component failure or invalid value (like compass vs GPS readings) and react to it.
    For any 'real' photo or video etc tasks, use an Octo.
    Logic in planning software & flight controller to warn if mission exceeds battery life when activated (because currently you can initiate a 10m auto mission when the battery is nearly flat - so guaranteed to crash!)
    Also, just remembered... a friend had a serious crash by accidentally activating an AUTO mission when 40 miles from the first waypoint (flown a few weeks prior). He thinks this was caused by radio interference - no way to know.
    The hex started flying towards the first waypoint, went out of radio range, hit a tall building and broke almost every component including GoPro and gimbal.
    There is currently no logic in the flight controller to determine that this mission was impossible and therefore refuse to start it.
    The logs and GPS track afterwards showed that AUTO had been engaged, and following the track by zooming out on google maps it went to the area of the 1st waypoint!
    A very expensive crash :(
    • Sometimes I remember to clear waypoints from the craft before I take off for the first time on an outing. I had better make this a required part of my setup procedure!
  • Old thread, but good question...
    My major crashes were caused by:
    1. operator (me) error
      1. could have been avoided with more practice on a small drone before trying things with the big one
    2. motor failure in air
      1. perhaps could have been spotted ahead of time if I had been more familiar with these motors and the noises they're supposed to make, and a good pre-flight check
    3. sudden surge upwards in Alt Hold mode, straight into tree branches
      1. not sure exactly what happened here, so unsure how to avoid
    4. a building breaking line of sight with the drone, causing loss of telemetry and video at the same time
      1. could have been avoided with more awareness of obstacles on my part
      2. also could have been avoided with RTL-on-Mavlink-loss instead of Land-on-Mavlink-loss
