today I made a good progress:
The range finder is connected and shows values (meter, volt)and changes when I move the copter up and down. :D
Now the rng finder has to be calibrated. I tried and changed all those parameter I think
they have influence but no success so far. shows wrong distance sitting on the flor:
I measured the distance from the edge of the sonar to the ground = 17 cm. But it shows 0.08.
Then I lift the copter to about 85 - 90 cm and the value shown is 0.40 (See pics)
Is there a divider i can set until the reading is more acurate?
(See MP pic attached)
I think this could be my last clue to solve: calibration of the distande to ground. :)
What values I can play around with?
(Unfortunately the WiKi makes no reference to the RNG finder HC-SR04 with the analog output board) :/
Hi :)
cool that the sonar works on APM.
What is the A1 pin for the Pixhawk??
I'm reading through the WiKi but there is no mention how to connect the HC-SRo4 to the Pixhawk.
I use the sonar with the second board attached where 3 pins come out.
The sonar shows a red led but no numbers in MP. I connect to the ADC 3.3 V plug in the middle.
Is that ok?
Hi :)
Is that ok?
What is the equivalent Pin A1 (APM) for the Pixhawk?
I tried to set up the sonar with the extra board (3pin) but no success so far.
Where can I educate myself or find information regarding how to make work this sonar with the Pixhawk? The Wiki has no info. :/
I purchased HC-SDR04 that has 3 pins connector and It finally worked for me last night. I have updated to firmware 3.2.1 (36b405fb).
Then go to the configuration/tuning tab and under Full Parameter list search for RNGFND_PIN and change the value to 1 ( This is Pin A1) . The value 0( Pin A0) did not work for me.
Disconnect the APM and plug the sensor in PIN A1 in the APM , them reconnect the APM to the computer.
cool - today I can post the pics :) (have access again)
pics:
Bernardo,
Use value 14 in the RNGFND_PIN. that worked for me.
thank you :)
I'll try it out soon and report my result.
......whilst some pics
Is that ok?
Is that ok?
HI,
I hope this work for you.
Thanks for that, I will investigate this and hope to get these working on an apm 2.8.
Hello. Did you solve it?
1
2
3
of 3 Next
