Dear Friends,
I have a problem when setup ArduPilot.
When the mode is moved to stabilize or fly by wire A, the throttle is always spinning fast and can not be controlled.
I try to do debug in mode 8 (from Jason), and I see the value of Throttle always ranged in 59 to 60. How to solve this problem?
Deni Suwardhi
    Hi, did you get this resolved, I'm got the same problem, but mine used to work until I switched ESCs.
    Try to check if you have the correct jumpers soldered on the back as shown in the wiki http://code.google.com/p/ardupilot/wiki/SolderingBoard
    and also have you made sure you are using the correct throttle pin as defined in the header file?
