Underwater Quadcopter
Hi
This may sound crazy.  How about a quadcopter designed for underwater use.  Brushless motors operate perfectly well submerged and the rest can be waterproofed quite easily.  Idea being that one would use small props, basically the quad would operate in a different medium but essentially it should still stabilise as it does in air.  I thought about escs (which don't like water) getting hot but they could be exposed, covered with tectyl or some other waterproofing spray.
As a fail-safe, waterquad would be slightly buoyant so in case of power loss, it would merely float to the surface.  One would then have keep throttle on all the time to stay submerged and power up to sink as opposed to normal operation.  I know that 2.4ghz does not work underwater but the older 35mhz systems do.  For fpv, 1.3ghz could be used ??  Also I wonder which flight controller would work best, kk2 maybe for cost-effectiveness.
Has this been attempted before and if so, any success?   Couldn't seem to find anything on this concept.  I'm itching to start building but somebody please stop me if I'm wasting my time.
          • Ah yes I see the four props and thus the craft is vertical in flight then drops down to horizontal for under water. You would only be able to control depth whilst moving forward or backwards but maybe some applications would be happy with that. You still wouldn't be able to control it more than about 5 cm under water though :)
  • Ok, now I'm day dreaming but wouldn't it be awesome to make one of these a hybrid?  Deepfly Dragon using ducted fans?
    • Wow that would be something but $1.5 million just for the water version I think it may be slightly out of my play list bracket.. :)
      A word of warning to anyone that reads this and thinks model ducted fans would be ideal for a ROV. The ducted fans you get in model aircraft are only built for thrust in one direction. You reveres the fan (and thus the thrust) and the darn things come apart....obviously I'm not sure if this is the case for all set ups but I believe it is the norm...
  • Why not build a Octocopter with four normal props for flight and the second set for underwater flight?  If assuming you can make it water tights, it would be an interesting project to try.  Of course software would be needed to switch on and off the two types of props based on mode of operation but I like the idea that you could fly it out to water entry point then submerge it and run underwater then surface and fly back.
    • The flight ones will work fine for the up and down element (z axis)  of a near neutrally buoyant craft so if you don't want to vector these some how to give X,Y control then (minimally) you only need one other motor with forward/reverse and a rudder.
  • Ever since I learned that brushless motors worked underwater I had this exact idea. I think the main issues would be getting accurate signal underwater, and dealing with the propeller sizes, because you'd need much smaller propellers underwater to move around. if you could overcome those problems it just might be the coolest thing ever.
      Your best bet for thrusters are either of these https://www.bluerobotics.com/store/
      • yes i have seen these thrusters.. but i have to use same motors for both air and underwater operations..
        • The same type of motor will work underwater but it will require a different prop to run at the same rpm.  Something that can fly and swim using the same motor/prop combination is not possible by the laws of physics.
          • I agree , that's  why you don't turn them at the same RPM. You need a brush less outboard that is capable of slow speeds, Many can't but some can...
DIY Robocars via Twitter
RT @knightsautoteam: Hi @diyrobocars, we are Orlando's first Autonomous racing club and would love your support. We are hosting our first K…
Jan 20
RT @Heavy02011: #VirtualRaceLeague: @DIYRobocars Race #14 - #ParkingLotNerds join us January 15th for #AutonomousRacing #RoboRace ⁦@DAVGtec…
Jan 16
RT @chr1sa: And after that came our races, 50 in all. This battle between these two Russians was the best we've ever seen -- incredible fig…
Jan 16
RT @chr1sa: Before our @DIYRobocars virtual race this weekend, we had a presentation from the team that won the Indy Autonomous Challenge i…
Jan 16
DIY Drones via Twitter
Dec 12, 2021
Dec 12, 2021
RT @chr1sa: Just a week to go before our next @DIYRobocars race at @circuitlaunch, complete with famous Brazilian BBQ. It's free, fun for k…
Dec 4, 2021
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Nov 28, 2021
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26, 2021
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25, 2021
@gclue_akira CC @NVIDIAEmbedded
Nov 23, 2021
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23, 2021
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23, 2021
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20, 2021
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20, 2021
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9, 2021
