Is there a better place than at the GPS heaader shown in red above?
Will this reading be appropriate for both the battery voltage monitor and the Air pressure sensor?
//0-8Thanks,
#define BATTERY_EVENT 1 // (boolean) 0 = don't read battery, 1 = read battery voltage (only if you have it wired up!)
//0-9
#define INPUT_VOLTAGE 5200.0 // (Millivolts) voltage your power regulator is feeding your ArduPilot to have an accurate pressure and battery level readings. (you need a multimeter to measure and set this of course)
Nathaniel
