What is this error sound coming from Pixhawk 1?
I am unable to identify what these sounds mean.
What is disturbing is that at the end of these sounds it reboots and then ARMS ITSELF with Mission Planner reporting that it is DISARMED.
The kill switch will NOT disarm the aircraft.
I can not make this error happen, it just does.  Occasionally I will get a normal boot.
No errors show on HUD, no errors reported in logs.
Any help is welcome and appreciated!
Video is linked here.
  • The fact remains that this error code, as it is sounded from pixhawk is either being misinterpreted or is not in the listed library of error sounds.
  • Upon recalibrating the transmitter these problems appear to have ceased.  Testing in progress.
    1. Removing the kill switch does not fix the problem
    2. Replacing the kill switch does not fix the problem
    3. This error is truly intermittent
    4. Formating the SD card has no effect
    5. Reflashing with arduplane 3.7.1 has no effect
    6. While arduplane 3.7.1 was loaded I did a RESET TO DEFAULT for the parameters, got a succesfull boot from the automatic reboot that resetting to default does
    7. Next boot of pixhawk 1 has the error sounds, so reset to default did NOT fix it
    8. Reflashed with Arducoptor 3.4.4.  Upon reboot error persists
  • The self arming only happens when this error is present.  This multirotor has more than 100 sorties.  Trying a few things, will report back.
  • The first tones are due to the coprocessor being updated, then update completes.. should be only when loaded with new firmware. As for arming, if always like that, could be configuration, anyway, you never know if it's a badly made one.
  • format the SD Card and see if your issue goes away.
DIY Robocars via Twitter
RT @circuitlaunch: Robot fun this Saturday (23) at Circuit Launch! From 10am to 4pm. Lots of robots, autonomous car racing training, tech t…
18 hours ago
RT @chr1sa: 10 of these autonomous racecars will be competing tomorrow at the Indianapolis raceway
18 hours ago
RT @a1k0n: Sync'd @joshu's GoPro w/ my datalogging; video is 2.5X speed, Google imagery upper-right. Found out my track boundaries are WAY…
Tuesday
RT @a1k0n: Also, at 45mph, the front tires literally blow up like a balloon and it doesn't have much front traction, so the car becomes fai…
Tuesday
RT @a1k0n: Okay, some datalogs! Green dots are precalculated racing line (from my crummy optimizer -- it veers to the middle after 2 for Re…
Tuesday
RT @a1k0n: Welp my @selfracingcars entry, hastily conceived heading filter and all, actually worked! Heading home, datalogs and videos to f…
Tuesday
Monday
Oct 15
RT @f1tenth: What can we learn from autonomous racing? Actually, a lot! To get an idea what you can do in this field and where the research…
Oct 11
Oct 11
RT @a1k0n: It's aliiiiiive! Less than a week until @selfracingcars and I'm just now digging this bad boy out. Been a crazy few months. Hope…
Oct 10
RT @OttawaAVGroup: Mark your calendars. CAV Canada is happening on Dec. 2nd, 10am-4pm EST. And guess what - admission is FREE! Get your ti…
Oct 6
RT @f1tenth: Our new 1:10 scale 3D racetrack is here. We will implement it in the @SVLSimulator in the next weeks so everybody can use it.…
Oct 6
RT @DAVGtech: Received sweet autonomous Ferrari's that we plan to demo at the @IndyAChallenge on our portable @donkey_car track. Let us kno…
Oct 6
Sep 30
Sep 9
